Mig vs. Tig Welder for Panel Replacement???
#1314431
10/03/12 12:24 AM
10/03/12 12:24 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
I'm toying with the idea of finally buying a welder to do some future panel replacement on my Cuda in all the usual places (trunk, drivers floor, inner fenders, maybe a quarter panel).
I've dabbled in using oxy/acetylene, mig and tig doing some practice stuff and have always like tig the best because of the puddel control you have. It has always seemed to me like you "know" the two pieces are being bonded, as opposed to mig which seems to have the potential to be a hot metal glue gun.
Mig welders sure seem alot more popular for DIY resto work, but is this just due to the cost difference, or are mig welders inherently better for doing this type of work?
I'd assume that having a foot-pedal tig setup might be a hinderence for doing panel replacement, but maybe some practice with a torch mounted control would allow similar flexibility to using a mig?
Seems like home tig units are getting more affordable. I was thinking maybe something like the Miller Diversion 165.
Any thoughts from folks out there that have used both mig and tig?
Re: Mig vs. Tig Welder for Panel Replacement???
[Re: areibel]
#1314439
10/03/12 04:14 PM
10/03/12 04:14 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Are migs really that much better at limiting heat?
Absolutely NOT.
Interesting that some pointed to the mig as being more versatile. I would have guessed that a tig unit would be more versatile since you can weld aluminum with quick and minor changes to the setup, unlike a mig.
Only if you do a lot of aluminum. But the average person will make more stuff out of steel ... who makes aluminum engine stands, aluminum hoists, aluminum car dollys, etc, etc, etc ? Nope, most projects will be steel.
As for migging aluminum, that's production stuff only. It ain't pretty and it usually lacks the penetration a tig will give you.
[Re: areibel]
#1314440
10/04/12 01:57 AM
10/04/12 01:57 AM
rss
Seattle, WA
You can mig aluminum, stainless too. You need to use different wire and I think different shield gas but it will do the job.
Yes, you can mig aluminum but as I understand it requires another gun because the aluminum wire has to be pulled instead of being pushed out the of gun. Converting a mig to weld aluminum isn't cheap and it isn't a quick simple change like for a tig welder.
[Re: Stanton]
#1314441
10/04/12 02:10 AM
10/04/12 02:10 AM
rss
Seattle, WA
On a final note, if you don't own a mig already then maybe that's what you should go for simply because it is more practical for any other projects you may have.
So I understand your point about most projects being done in steel, but why do you say a mig unit is more practical for any other projects? If we don't consider that migs are faster and intially cheaper to buy, would you still consider the mig as being more practical?
Thanks for the input
[Re: DaytonaTurbo]
#1314443
10/04/12 09:38 AM
10/04/12 09:38 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Shouldn't "faster and cheaper" be enough ?!?!? The speed and ease of use of a mig makes it way more practical than a tig. With a mig you turn on the gas, point and shoot. With a tig you have to fart around with the pedal, get yourself in a decent position to access with both the torch and the electrode, and then you need two hands to tig (and usually a foot!). And then running the bead will take longer. Ease of use is by far the biggest advantage. I could teach anyone how to mig decently in about 1/2 hour but tig takes hours of practice to get it right.
