I don't know the exact model you are talking about. I have two slightly different Lakewood big block blowproof housings. In my experience on the 64/65 you have to beat the little sheet metal seam on the tranny tunnel flat.
This is on cars with the correct K-member. If you have a 66-up K-member on your car it moves the bell back towards the rear and I have heard of people having to heat up the tunnel and beat on it for clearance.
Also, obtaining the correct clutch fork pivot angle is a pain. I recommend talking to Wayne at Brewer's and he can tell you what is needed. For some reason the Lakewood clutch fork pivot is located all wrong for the 64/65 b-body cars with the big block. I don't know about small block...
-Jason
