440 engine ID...possible 6 pack motor?
#131397
10/02/08 10:02 PM
10/02/08 10:02 PM
Posts: 738 New York
R/T1968R/T
New York
Re: 440 engine ID...possible 6 pack motor?
[Re: R/T1968R/T]
#131398
10/02/08 10:36 PM
10/02/08 10:36 PM
1969 440 block with 1970 Six Pack pistons...
[Re: vdriver]
#131400
10/02/08 11:01 PM
10/02/08 11:01 PM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
Looks like some "hanky panky" went on when someone stamped the VIN # . Looks like somebody tried to stamp an M code over the L . Looks like an Oct 5 finish date , about 5 months before the 69 1/2 M code RM/WM cars . I don't know, it just plain looks fishy. Greg Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios We can restore YOUR radio usually in less than 7 days Visit our NEW website.. http://www.wardsclassiccarradiorepair.comgregward@mchsi.comphone 256-852-0955 ![](http://home.mchsi.com/~gregward/h15.jpg)
[Re: R/T1968R/T]
#131401
10/02/08 11:04 PM
10/02/08 11:04 PM
Posts: 29,662 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
From what I remember it was from a 69 GTX, but something does not make sense.
RS23 is the 1969 GTX prefix.
The only Sixpack / Six Barrel cars in 1969 were the Super Bees & Road Runners with the A12 package.
[Re: Alaskan_TA]
#131403
10/03/08 12:28 AM
10/03/08 12:28 AM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
9A144278 was built on or about 10/10/68 ... so the 10-5 makes sense appears to have been an original 440 4bbl engine from a GTX ![](/ubbthreads/images/graemlins/shruggy.gif) maybe
[Re: R/T1968R/T]
#131406
10/03/08 10:52 AM
10/03/08 10:52 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
I looked at it more closely last night using a jewelers loop. The fifth digit is an L. it appears the block was struck by a tool or something which left two large scratches. You can see they are not parallel. The bore is stock and the pistons appear stock. Maybe someone transplanted the guts from another motor years ago.Question, should I try and remove the two scratches?
Do you have the car it belongs to ? if not the point of removing them would be ?
There is a 15 year gap between you aquiring it and it being originally being built , ANYTHING is possible .
[Re: JohnRR]
#131407
10/03/08 10:58 AM
10/03/08 10:58 AM
That looks like an upside-down 5, not a 2, in "HP2". They must not have had a full set of numbers.
#131409
10/03/08 11:07 AM
10/03/08 11:07 AM
JohnRR
No it's typical of the 2 I have seen on that pad , look at the 5 , it's not even close .
