Re: Motorhome good or bad idea?
[Re: Eric]
#1313547
10/01/12 11:14 PM
10/01/12 11:14 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks Eric. When he said he wanted 5000 dollars for it I almost choked. Matt and I took it for a ride 2 hours later and bought it. He used to race in the AHRL. I think that's right (all harleys).
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: MoParFish]
#1313549
10/02/12 12:28 PM
10/02/12 12:28 PM
Posts: 4,660 Motor City
6PKRTSE
Motor City
My Brother just picked this one up a couple of weeks ago. We are going to see how it pulls & tows. 440 4 bbl with 44,000 original miles.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: FASTFISH420]
#1313551
10/02/12 07:26 PM
10/02/12 07:26 PM
Posts: 404 Central New York
bfury
Central New York
Advice from a previous owner of a Fleetwood 35' motor home. Do not buy an old motor home, in general they are poorly constructed with plywood that tends to get wet and rot. Frequent water leaks around the body and roof. The wiring for lights and etc. is done with scotch loks that allow water in and corrosion. The 460 Ford is notorius for cracked heads due to uneven expansion of the exhaust manifolds compared to aluminum heads. Check the internet for the horror stories, Chevy also, You will need an auxilliary trans cooler and heed the other advice given. Get AAA with RV towing and maintain the motor home frequently. There are many positives but buy a fairly new one and sell before 10 years old.
No Stock
[Re: Triple Threat]
#1313556
10/04/12 01:25 PM
10/04/12 01:25 PM
Posts: 43,902 Bend,OR USA
Cab_Burge
Dustin, how many lugs are on the axles on this unit?
[Re: Cab_Burge]
#1313557
10/04/12 01:29 PM
10/04/12 01:29 PM
Triple Threat
Renton Washington
No clue, it was borrowed for 2 weekends a few years ago and then returned to its rightful owner.
[Re: Chassisman]
#1313559
10/04/12 02:18 PM
10/04/12 02:18 PM
Posts: 453 Holly, MI
JackGTX440
Holly, MI
Beautiful trailer. What brand is it?
Jack Irons Jr.
'67 GTX, turbo 6.1 HEMI
[Re: JackGTX440]
#1313560
10/04/12 02:23 PM
10/04/12 02:23 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
Vintage...53' with 9' ceilings... 25' of living quarters. Has a big shower ... 7,000 watt Onan ... tall enough you can walk next to the bed up top. It's a 2001 ...in really good shape.
http://www.vintagetrailers.com/
[Re: Chassisman]
#1313561
10/05/12 01:24 AM
10/05/12 01:24 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
What all do you have to have to keep DOT off your tail while pulling that thing?
License Equipment Inspection Etc???
[Re: Chassisman]
#1313563
10/05/12 07:16 AM
10/05/12 07:16 AM
Challenger 1
Cincinnati, Ohio
I just upgraded to a slightly bigger trailer. I love towing with the dually.... It gives you complete freedom when at the track. We race in Denver alot and are there for 7-9 days....so if we were in a MH we would be stuck at the track. With the dually and LQ trailer we just dump the trailer and run around in the truck. Also makes it nice when you need something from town or a beer/booze run....LOL....plus in Calif it's registered as a 3 axle trailer...35.00 for 5 years... ...we got 12-14 MPG hauling it back from Memphis Tn to Central Calif... my F350 isnt stock....but still pulled 6% grades at 55-60 no problem.
Got news for ya, your dually ain't gonna like that heavy trailer, now it's time for a larger tow vehicle.
I use a toterhome and my pit vehicle inside my trailer if I'm gonna pull something that long.
[Re: Challenger 1]
#1313564
10/05/12 12:28 PM
10/05/12 12:28 PM
Chassisman
Chowchilla,ca
My dually doesn't even know it's back there...it's not a stock F350... it make s 715 hp...1150 ft lbs... has dual rear calipers....8,000 lb Firestone bags....has towed over 44,000 lbs.... 6 speed manual with a gear vendors OD..... runs 12's when on the race side of the tuner.....towing my 40' trailer I could pull out of Aspen Colorado at 70 mph.....it does just fine....but I'm looking at FL20s and FL50's......what works for some doesn't for others....to each heir own.....and I don't have room for an extra vehicle with 3 race cars and a monster golf cart.
