65 satellite glovebox emblem removal #1313390
09/30/12 08:41 PM
09/30/12 08:41 PM
rwynsma Offline OP
rwynsma  Offline OP
How do I get satellite emblem off of glovebox. Thanks ron
Re: 65 satellite glovebox emblem removal [Re: rwynsma] #1313391
10/03/12 10:33 PM
10/03/12 10:33 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
ron,
Try a solvent and see if it's just glued on... I don't think it's original, so unless it was mounted through the lid, it's probably just stuck on somehow.
Of the three '65 Satellites I have photos of, including my own, none of them have glovebox lid emblems. I don't see glovebox emblems on any online photos either.
Best, -Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 65 satellite glovebox emblem removal [Re: 67SATisfaction] #1313392
10/04/12 09:45 AM
10/04/12 09:45 AM
rwynsma Offline OP
rwynsma  Offline OP
Thanks art i"ll give it a try. It looks like the same emblem that's on the trim piece betweeen tail lights. I tryed dental floss behind it, but it stops right where the first stud is.. Thanks ton
Re: 65 satellite glovebox emblem removal [Re: rwynsma] #1313393
10/06/12 09:02 PM
10/06/12 09:02 PM
Albany, NY
Albany, NY
Hmm.. Then I understand your problem. Your evidence may point to a previous owner who drilled the aluminum skin for the studs and stuck it in? Or the floss is getting hung up on the stump of the trunk emblem's stud..?
