alternator mounting suggestions w/ crank trigger wheel #1312485
09/29/12 03:29 PM
09/29/12 03:29 PM
SoCal
jake4cars Offline OP
SoCal
What crank pulley and alternator bracket assembly do you guys use with an MSD trigger wheel, I am thinking of using a Nippondenso alternator, hopefully someone knows of a low mount kit.
Does anyone make a plug or something to go from the factory alternator to the Nippendenso.
Thanks!
Joey
Re: alternator mounting suggestions w/ crank trigger wheel [Re: jake4cars] #1312486
09/29/12 07:05 PM
09/29/12 07:05 PM
AndyF Offline
AndyF  Offline
Depends on some other parts that you have such as type of water pump and whether or not you're running a motor plate.
Re: alternator mounting suggestions w/ crank trigger wheel [Re: AndyF] #1312487
09/29/12 08:00 PM
09/29/12 08:00 PM
s.e. michigan
top8x7b Offline
top8x7b  Offline
s.e. michigan
I have msd crank trigger and motor plate on big block ,i use DMI low mount with crank trigger feature ,the alternator is a suzuki samari alt looks like.a small.east coast works great never put a battery charger.on at the track
Re: alternator mounting suggestions w/ crank trigger wheel [Re: top8x7b] #1312488
09/29/12 08:54 PM
09/29/12 08:54 PM
Penna
70satelliteguy Offline
Penna
"I have msd crank trigger and motor plate on big block ,i use DMI low mount with crank trigger feature "
I use Power master Alternator.
Mike
Re: alternator mounting suggestions w/ crank trigger wheel [Re: jake4cars] #1312489
09/30/12 12:16 PM
09/30/12 12:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I made a spacer That sat the water pump ear. This set the pulleys in line. Welded the spacer to the pump. Marked an arc on the motor plate and drilled a bunch of holes along the arc. Took a die grinder to connect all the holes to form a slot. Cut a second spacer and bolted the whole thing to the plate. Simple and cheap.
Doug
Re: alternator mounting suggestions w/ crank trigger wheel [Re: dvw] #1312490
09/30/12 12:26 PM
09/30/12 12:26 PM
SoCal
SoCal
I should have mentioned that I am not using a motor plate and the water pump will be a self contained unit like a Mezierre or something along that line. I tried posting a photo of the engine mocked up in the car but Moparts will not allow it, the file size must exceed the allowable limit.
Joey
Re: alternator mounting suggestions w/ crank trigger wheel [Re: jake4cars] #1312491
09/30/12 12:38 PM
09/30/12 12:38 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I think is this one mentioned above that low mounts the alternator and the crank trigger.
http://www.dotymi.com/Alternator_brackets.htm
Re: alternator mounting suggestions w/ crank trigger wheel [Re: PC-CHARGER] #1312492
09/30/12 12:59 PM
09/30/12 12:59 PM
SoCal
SoCal
That is exactly what I am lookng for. Thanks! to everyone who responded.
Joey
