Re: soldering iron ?????
[Re: 70rrclone]
#131248
10/02/08 07:00 PM
10/02/08 07:00 PM
moparpollack
Lil Herman
Lil Herman
85086
What are you soldering? Specifics????
[Re: 70rrclone]
#131249
10/02/08 07:26 PM
10/02/08 07:26 PM
RapidRobert
Get a large soldering IRON. I was given one that was the size of a small billyclub & it worked better than any soldering gun I ever had as it would get so hot that it would heat the wire & melt the solder so quick that there wasn't time for heat to wick along the wires & melt insulation but still use a pair of clips that look like part of a nail clipper on either side of your work to wick away as much heat as possible.
[Re: coro500net]
#131255
10/02/08 10:14 PM
10/02/08 10:14 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
I like the butane irons. No cord,easy to use in all locations. Some kits come with different tips even one that you use for shrink tubing.
Much faster than the electrics I have.
[Re: 70rrclone]
#131258
10/09/08 03:08 PM
10/09/08 03:08 PM
Posts: 103 Tampa, FL
Saint Crispan
Tampa, FL
Keep in mind that what you're soldering will determine the wattage. Smaller work (resistors, diodes, speaker wires, etc) will be fine with a 35W but if you want to put new wires under the hood 14, 12, 10 gauge), you'll need a big honkin' IRON. (I found that out when I tried to solder wires...the Radio Shack special just ain't getting the job done.)
In any case, always remember to prep the tip before you use it, without a good tinning, the tip will not perform.
