Re: plastic straw in cylinder [Re: bonefish] #1312347
09/30/12 02:56 PM
09/30/12 02:56 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
what kind oilpump you usin,i want one.i tiny little shard trashed mine.
Melling std volumn...I was a tad bit surprised when I saw the parts on the pick up, truck had good oil pressure, but I pulled the pump apart...Had a few marks so I tossed it.
Some of the the intake valve guides were broken off too...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: plastic straw in cylinder [Re: Adobedude] #1312348
09/30/12 08:05 PM
09/30/12 08:05 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I'd be afraid the melted plastic would cause some damage? I wouldn't use glue. It might get in the cylinder. It's a tough one but maybe you could use a coat hanger and attach some duct tape to it with a sticky side out and fish the straw out? One layer sticky side down and overlap it with the layer sticky side out and roll it under at the end. I think it would not be too thick to fit thru the plug hole and should be safe enough it won't fall off? Can you see the straw with a flash light?
Re: plastic straw in cylinder [Re: mopartial] #1312349
09/30/12 08:54 PM
09/30/12 08:54 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've had this happen a few times, I take a air hose and blow it in the hole and the tube flys out.
Re: plastic straw in cylinder [Re: Challenger 1] #1312350
09/30/12 09:54 PM
09/30/12 09:54 PM
central PA
mopartial Offline OP
central PA
Not feeling too lucky plus ticked off at myself for letting this happen, so I was determined to get it out...
I had to remove this little wooden partition in the bilge, then doing a headstand, I could see the spark plug hole... (Thru the hole is the little fiberoptic light thingy.)
If it aint broke, dont break it.
Re: plastic straw in cylinder [Re: mopartial] #1312351
09/30/12 09:56 PM
09/30/12 09:56 PM
central PA
central PA
This was encouraging but the rest wasn't all that easy. I brought piston up to make it easier to reach. And straw got binded up in there. (?at piston top or in a closing valve?) So just for more drama it came out in two pieces.
Mission accomplished.
Is oiling each cylinder even helpful after a thorough fogging thru carb?
Thanks to all posters.
Re: plastic straw in cylinder [Re: mopartial] #1312352
09/30/12 09:57 PM
09/30/12 09:57 PM
central PA
central PA
If interested, here is my favorite new plaything. 1986 Chris Craft 210 LTD Cuddy Cabin. 5.7 liter OMC Stringer 800 Sterndrive. 2012 Shorelander tandem axle trailer.
FWIW its non-Mopar...
Re: plastic straw in cylinder [Re: mopartial] #1312353
09/30/12 10:28 PM
09/30/12 10:28 PM
alot if not all will be burned off. yes GENEROUSLY lube each cyl at the plug hole & hand turn it over to coat the walls
Re: plastic straw in cylinder [Re: Supercuda] #1312354
10/01/12 08:38 AM
10/01/12 08:38 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You're making that up, aren't you.
Nope, serious.
Heck, it was "just" a 318
Yah, I can understand that thinking. Pfffttt....Girly-man small block so no big loss.
Re: plastic straw in cylinder [Re: mopartial] #1312355
10/01/12 10:09 AM
10/01/12 10:09 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
For years, I've just run the motors while I spray fogger into the carb until they choke out. Never pulled the plugs to fog the cylinders seperately. I've never had an issue.
Re: plastic straw in cylinder [Re: mopartial] #1312356
10/01/12 04:03 PM
10/01/12 04:03 PM
State of terror
52savoy Offline
52savoy  Offline
State of terror
Good to see you got it figured out.
It could have been the "straw that broke the camels..."
