Re: Down on Power
[Re: tsanchez]
#1312259
10/21/12 11:39 AM
10/21/12 11:39 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
that dyno sheet looks weird, tq and hp cross at 5600 rpm or so, should be at 5250.
Lets check that out ..... The guy at the controls is David Barton Frame 1:48 http://www.youtube.com/watch?v=9rG0doYzstE
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Down on Power
[Re: chryco]
#1312260
10/21/12 03:23 PM
10/21/12 03:23 PM
Posts: 235 Gilbert AZ
tsanchez
Gilbert AZ
After looking at the graph again it appears the numbers on the left are not aligned, if you match them it does cross at 5250. never mind ![](/ubbthreads/images/graemlins/hammer.gif) Seems something happened from dyno room to chassis though as it does underperform.
Re: Down on Power
[Re: chryco]
#1312263
10/22/12 03:45 AM
10/22/12 03:45 AM
chryco
Winnipeg ,Mb. CA.
I just received some proof pics from the track photographer which now show the launch. I see the car pics up the wheels lets them down then pics them up again (not as high) all from initial launch to just about the tree. It did this in all three sets . Maybe I am starving for fuel ? I`d love to print the pics, but I haven`t paid for them yet. chryco
Re: Down on Power
[Re: chryco]
#1312264
10/22/12 09:06 AM
10/22/12 09:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you have jet extensions in the secondary ![](/ubbthreads/images/graemlins/wave.gif)
Re: Down on Power
[Re: chryco]
#1312268
10/22/12 08:49 PM
10/22/12 08:49 PM
MR_P_BODY
No I do not. Something else for my Xmas list ! Thx ! chryco
Most likely this is your problem... and a cheap fix ![](/ubbthreads/images/graemlins/wave.gif)
Re: Down on Power
[Re: chryco]
#1312270
10/23/12 01:25 PM
10/23/12 01:25 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You're a bit beyond my normal realm - but in terms of basics - the PG is for lighter cars - under 2800lbs race weight is what I've always been told. So I'd think it would need mroe gear. But - before that I think the fuel system needs some work. I'd want -12 from sump to regulator and -10 from reg to carb if you're only filling through (2) inlets rather than (4). I don't know that two -8 can feed it that well considering the launch. Once the rest is worked out the convertor may be fine.
Re: Down on Power
[Re: chryco]
#1312273
10/25/12 12:03 AM
10/25/12 12:03 AM
chryco
Winnipeg ,Mb. CA.
Thanks for all the help on this problem Guys! I now have a direction to aim for and get that car down the track a little faster / quicker next season. I did FINALLY find my time slips and here`s the most legible one also the faster of the day. chryco Mine`s #426 (left lane) ![](http://i1131.photobucket.com/albums/m553/debobs557/scan0003.jpg)
