what size nut on 8 3/4 pinion yoke?
#131180
10/02/08 01:23 PM
10/02/08 01:23 PM
Im going to change my seal this weekend and might need to pick up a socket (I havent removed the driveshaft yet)
Re: what size nut on 8 3/4 pinion yoke?
[Re: NachoRT74]
#131182
10/02/08 01:33 PM
10/02/08 01:33 PM
thats great. I already have one!! 3/4" drive too.
thanks
#131183
10/02/08 02:50 PM
10/02/08 02:50 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I think it depends on your yoke/pinion spline count. Ive got 2 that have 1 1/4 nuts, both 29 spline units. My 10 spline unit uses a smaller socket, say 1 inch or so.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: DoctorDiff]
#131187
10/02/08 05:07 PM
10/02/08 05:07 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Pre '72 10 spline yoke 1 1/8" socket Post '71 29 spline yoke 1 1/4" socket
I was thinking the diffy kit I bought from you had 2 nuts of different sizes included. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dart 340]
#131188
10/02/08 11:45 PM
10/02/08 11:45 PM
Posts: 6,099 Valencia, España
NachoRT74
Valencia, España
mmm interesting... didn't know about the diff with diff splines.
[Re: NachoRT74]
#131189
10/03/08 12:21 AM
10/03/08 12:21 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Dr. Diff is correct as usual. Easy way to determine what spline count you have! Impact is easiest, but if you have to brute force it off with a breaker bar, do it with the tires on the ground or the E brake on! You can also use a big [Edited by Moparts - Keep it clean] pipe wrench around the U joint saddle for a brace, but impact is golden.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
