question on installing full floor pan on B-body #1311625
09/27/12 06:59 PM
09/27/12 06:59 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Hey,
Question for those who have installed a full floor pan on a B-body, in this case a 69 charger.
I have the pan set in the car and I am making the final adjustments before getting it ready to weld in. I have noticed that the fit at the firewall is not very good. It needs to come down more but I cant get it to do so.
I have read others having fitment issues at the firewall but nobody gets into detail as far as what the issue was or what they did to resolve it.
thanks!!
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: question on installing full floor pan on B-body [Re: 69charger440_6pa] #1311626
09/27/12 08:09 PM
09/27/12 08:09 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Tilt the back of the pan up and clamp the pinch seam at the firewall,then stand on the floor pan until it rests on the rockers and frame rails. I did an AMD floor pan and this worked great.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: question on installing full floor pan on B-body [Re: chargervert] #1311627
09/27/12 08:50 PM
09/27/12 08:50 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I had the same issue and took some wood pieces (think short 2x4's) and wedged them in between the floor and the dash to push the floor down and then clamped the pinch weld as noted above.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: question on installing full floor pan on B-body [Re: 5wndwcpe] #1311628
09/28/12 02:35 AM
09/28/12 02:35 AM
Oakley CA
Oakley CA
thanks guys I got it. Just took more persuasion that I thought it would.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: question on installing full floor pan on B-body [Re: 69charger440_6pa] #1311629
09/28/12 08:44 AM
09/28/12 08:44 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Good suggestions and input since I'll be doing it too (well, having someone do it, but I can pass on the suggestions).
Thanks Pete...
Troy
Houston Mopar Connection Club
Re: question on installing full floor pan on B-body [Re: 69charger440_6pa] #1311630
09/28/12 01:21 PM
09/28/12 01:21 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Here is a good post on this subject from the A12 site...
http://a12mopar.com/yabb/YaBB.pl?num=1244992533/0
