Carter AFB jetting help needed...... #131144
10/02/08 09:59 AM
10/02/08 09:59 AM
Colorado
tcs69rt Offline OP
tcs69rt  Offline OP
Colorado
I moved from sea level to 8000 feet elevation. The jets in it are 120/400 & 395/395. I bought a strip kit but am not sure what to put in it. Anybody living this high up? What do you suggest? Also, do I retard the timing to 16 degrees for the 440 in my Charger? Thanks! TC
Re: Carter AFB jetting help needed...... [Re: tcs69rt] #131145
10/02/08 12:04 PM
10/02/08 12:04 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
??? 8,000 feet elevation?? Your location shows GFAFB and if you're anywhere near there you're about 7200 feet lower than you think.
Re: Carter AFB jetting help needed...... [Re: tcs69rt] #131146
10/03/08 01:33 AM
10/03/08 01:33 AM
Retired now in Tennessee
Chi_Town_Runner Offline
Here's a for you.
I moved from 900' to 6500' and would also like to know.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Carter AFB jetting help needed...... [Re: Chi_Town_Runner] #131147
10/03/08 08:12 AM
10/03/08 08:12 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Save youself a lot of grief and beg borrow or buy a LM1 or Autometer AFR meter. The first thing I'd do is play with the springs and metering rods, you need to lean the engine out at those altitudes.
