Re: 318 LA to 360 Magnum Swap
[Re: Fury Fan]
#1311431
09/30/12 03:23 PM
09/30/12 03:23 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
How does that cam snout extension fail if the bolt is torqued correctly? I've used a few of them the first one I bought has almost 100k on it
I wondered that too. Combination of high RPM and higher-ouput fuel pump, maybe? And maybne not torqued properly so teh clamp force between button & cam was low, causing the little key to carry more load?
I've got a friend that has used his extension for almost 5 racing seasons using my Carter (made for NASCAR) fuel pump & his motor stays between 4000-7000 RPM & it's never failed
