Page 2 of 3 1 2 3
Re: Any finished Dakota swap pictures? [Re: mbmopar] #131084
09/20/10 12:59 AM
09/20/10 12:59 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looking good
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131085
09/21/10 01:08 AM
09/21/10 01:08 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Six lug wheels aren't a big deal for me. I found a cool set in the six lug dakota pattern.
I was curious about the actual frame/suspension dimensions.
When they went away from the boxy look, there were some magazine articles that said it was still the same truck underneath. I'm wondering how acurate those comments actually were.
The first swap we started was with a 6 bolt wheel frame (year unknown), and the one I'm currently doing is a 5 lug frame (1990) and both frames looked the same to me, but I don't have any measurements to back me up. Under a 48 Plymouth coupe, the stock Dakota track looks just about right, I'll try to take a few pictures tomorrow. Gene
Re: Any finished Dakota swap pictures? [Re: poorboy] #131086
09/23/10 10:50 AM
09/23/10 10:50 AM
Kentucky
Flipper1938 Offline OP
Kentucky
Is it tomorrow yet? I'd love to see pics of your project.
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131087
09/23/10 10:34 PM
09/23/10 10:34 PM
Freeport IL USA
Freeport IL USA
Ummmmmmm, no? LOL!
Sorry got sidetracked. The weather has been really nice to work on the project (it's outside) and I keep forgetting to take pictures. Hey, I'm getting old.
We will see how I do tomorrow.
Here is a picture of when I drug it home.
Gene
Re: Any finished Dakota swap pictures? [Re: poorboy] #131088
09/27/10 02:11 AM
09/27/10 02:11 AM
Freeport IL USA
Freeport IL USA
Here is a picture from the rear, of my 48 Plymouth business coupe. The car is not yet complete, but you should be able to get an idea how the tires fit in the fenders.
For the record, the Plymouth body and rear fenders are not modified other then where it was clearanced to fit on the stock shortened 90 Dakota frame. The complete Dakota frame was used, it was shortened 8", but the rear axle, springs, shocks and original 6" Dakota wheels are intact as used on the truck. The 48 body shell was braced and cut at the floor pan, then lowered onto the shortened Dakota frame. The car will be a street version of a mid 60s dirt track race car. I will be using the Dakota frame, the cab floor and firewall, the seat, steering, and drive train (EFI v6, 5 speed, 8 1/4). The Dakota was an 8' box truck and I'm installing the floor of the truck box as a floor in the rear of the car, trimmed to match.
For those interested, I shortened the wheel base 8" (removed just in front of the fuel tank). I set the Dakota cab floor pan back 7" (this was so the firewalls were in the same relative location to each other) and relocated the front cab/floor mounts back 7" and built new rear cab mounts. What used to be the rear of the truck cab is about 2" in front of the original fuel tank. I moved the engine and transmission back 7" by modifying the motor mounts at the frame and relocating the trans cross member. I cropped the rear frame rails 4" rearward of the rear cross member, the front and rear suspensions are unmodified at this point. The box floor was trimmed at the wheel well width, and cut into two parts making a front 1/2 and a rear 1/2. The box floor is bolted to the frame with a 1/2" rubber spacer between the box and the frame at all bolt on locations. The box floor uses the factory cross member bolts to the frame at the fuel tank cross member on the front 1/2 and at the rear edge of where the rear of the wheel wells would have been on the back 1/2 of the floor. The rear of the box floor is bolted with new fabricated mounts at the rear frame cross member. The box floor is 6" above the cab floor pan and about ends 6" in front of the fuel tank cross member.
I am installing a 4 point roll cage in this car, and the main hoop will be attached to the floor pan(s) at the step up location. The cab floor still has the factory reinforcing cab mounting intact and is bolted to the frame using the factory rubber mount system and this bracing and mount is 6" in front of the fuel tank cross member. I used the front of the truck box to fabricate the step up with 2 1/8" plates at each side to attach the roll bar main hoop to. The floor pan and the box floor and the 1/8" plates are all attached to the inner structure of the 48 body. I have built new body mount area on the front of the cab floor at the firewall and all that is attached to the 48 body at the front door post and firewall supports. New inner and outer rockers are being fabricated that attach the front and rear door posts together and attach to the floor pan. The front posts of the roll cage will attach to 2 1/8" plated welded to the floor pan at the front body mounts. The box floor is welded to the 48 body inner wheel wells all the way from the rear door post to the rear body mounts at the rear frame cross member and the floor seam between the front 1/2 and the rear 1/2 will be welded closed. I had to cut the rear floor to install it in the car. There is a total of 10 rubber, bolt through, (1/2" grade 5 bolts) body mounts that attach the body shell to the frame with the roll cage attaching to 1/8" plates within inched of 6 of those mounts. The roll cage will likely be attached to the 48 body structure and the seat belts will attach to the cage. Keep in mind, this will be a street driven car.
I believe I'm going with cut rear fenders and the front fenderless with the hood cropped. There will be step type rear bumper with the stand off bars and the front will probably be the Dakota front bumper cropped a bot with stand off bars. There will also be nerf bars on the side of the car. I'm thinking about standard offset 7" wheels with an aggressive 70 series truck tire.
The Dakota was a running truck with about 120K miles. I'm intending on rebuilding the brakes, front suspension and running new fuel and brake lines and hoses. I will put a new clutch in it, and there are a couple pieces of glass to replace (all flat). I'm hoping I will have it on the road in the spring, 2011.
Pictures posted in seperate replies, first is general rear view, body is at stock Dakota height.
Re: Any finished Dakota swap pictures? [Re: poorboy] #131089
09/27/10 02:12 AM
09/27/10 02:12 AM
Freeport IL USA
Freeport IL USA
Rear view, left side.
Re: Any finished Dakota swap pictures? [Re: poorboy] #131090
09/27/10 02:12 AM
09/27/10 02:12 AM
Freeport IL USA
Freeport IL USA
Right side rear view
Re: Any finished Dakota swap pictures? [Re: poorboy] #131091
09/27/10 02:13 AM
09/27/10 02:13 AM
Freeport IL USA
Freeport IL USA
Left side side view
Re: Any finished Dakota swap pictures? [Re: poorboy] #131092
09/27/10 02:14 AM
09/27/10 02:14 AM
Freeport IL USA
Freeport IL USA
right side side view
Re: Any finished Dakota swap pictures? [Re: poorboy] #131093
09/27/10 02:15 AM
09/27/10 02:15 AM
Freeport IL USA
Freeport IL USA
Side view of the whole car
Re: Any finished Dakota swap pictures? [Re: poorboy] #131094
09/27/10 02:17 AM
09/27/10 02:17 AM
Freeport IL USA
Freeport IL USA
Step up from Dakota cab floor to Dakota box floor
Re: Any finished Dakota swap pictures? [Re: poorboy] #131095
09/27/10 02:18 AM
09/27/10 02:18 AM
Freeport IL USA
Freeport IL USA
Dakota front floor pan installed in the 48 body
Re: Any finished Dakota swap pictures? [Re: poorboy] #131096
09/27/10 02:21 AM
09/27/10 02:21 AM
Freeport IL USA
Freeport IL USA
Trying to decide if I want to go fenderless on the front. Last picture for tonight. Gene
Re: Any finished Dakota swap pictures? [Re: poorboy] #131097
09/27/10 04:35 PM
09/27/10 04:35 PM
Kentucky
Kentucky
You didn't throw away anything from the Dakota did you? Nice job putting the two together.
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131098
09/27/10 09:10 PM
09/27/10 09:10 PM
Freeport IL USA
Freeport IL USA
Ha, not much for sure! I even used the box sides for replacement metal on the coupe quarters and filler pieces along the floors and sides of the body! It helped the Dakota was real solid in most places. The floor pan was spotless and the box had a topper on it all of its life, so the inside of the box was really nice as well. The rockers were gone, but the inner rocker piece was decent, the box outer wheel wells were bad, and the front fenders were junk. I'm going to cut up the real nice doors so I can use the door latches, striker, and handles. I might be able to adapt the window lift system as well. That stuff is all junk in the coupe. I think when I'm all done, I'm going to be left with the hood, tailgate, rad support, and rear tail lights, but that's still subject to change.
Don't suppose your going to believe this one will be a cheap project, eh? I'm going to have as much money tied up in getting the car titled and licensed in my name as I'll have in the rest of the build, almost. I'm going with a bonded title so there won't be any issues with the state of IL in the future. I expect to be on the road for under $3,000 next spring. Gene
Re: Any finished Dakota swap pictures? [Re: poorboy] #131099
09/28/10 03:24 PM
09/28/10 03:24 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
GENE thanks for sharing, a pic of the adapted fire wall when you get a chance, very intresting, if it was on a street rod,,the donor fire wall would make it easy to adapt the donor vehicle heat and A/C steering column,,etc,,very kool,,,
i use to live in ill,,,whats the bonded title??
oh and i say front fenders,just my 2 cents
2015 cherokee
2013 R/T classic
Re: Any finished Dakota swap pictures? [Re: fstfish66] #131100
09/29/10 12:32 AM
09/29/10 12:32 AM
Freeport IL USA
Freeport IL USA
I discovered as I progressed through that a Dakota firewall is not straight! The driver side is farther forward then the passenger side by almost 3"! I intended on using the Dakota heat/ac box as well, but I'm not sure its going to fit. The blower fan on the box sits right of where the AC hoses connect to the unit. That happens to be the area that get narrow on the 48 because the hood hinge is outside the body at the same point the blower fan sits inside. I'm going to have to do an actual test fit, it will be real close, one way or the other.
The state of IL has determined any car, 48 or older can not be identified by serial numbers, body numbers, frame numbers and engine numbers accurately. Unless all those numbers match up 100% correctly, they say they can not prove the title you hand them belongs to the car you want to title. About October of 2009, they determined every 48 and older car has to have a bonded title unless one of 2 things are present.
1) every number has to be easily readable, and all numbers have to match the paper work you have, or
2) you have to transfering a current IL title. Both are iffy.
The current process is to build the car, have it appraised, have it pass a NSRA safety inspection, buy a bond for 3 times the appraised value, you have to list all the major componets origin, and have a discription of the build process. You send all that down state with the proper form and payment and in about 3 months they issue you a new vin number (they install) and matching title. Then that department sends your paper work over the the dept of tax collection where they try to get 8% of the appraised value.
Wish I could say its whats coming, but unfortunately, its already here. Be prepared, once IL gets by with this for a while, I expect most states to follow suit. Gene
Re: Any finished Dakota swap pictures? [Re: poorboy] #131101
09/29/10 12:33 AM
09/29/10 12:33 AM
Freeport IL USA
Freeport IL USA
Other side. I'll try to get better pictures. Gene
Re: Any finished Dakota swap pictures? [Re: poorboy] #131102
09/29/10 01:13 AM
09/29/10 01:13 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
well it could be worse,,and not be able to build it or title it,,,ill was alwasy easier on regestration,,,,im in PA now,,leaving soon as i can,,,,,its all money driven,,but at least its doable in ill,,,,
2015 cherokee
2013 R/T classic
Re: Any finished Dakota swap pictures? [Re: fstfish66] #131103
09/29/10 10:29 PM
09/29/10 10:29 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Nice Job.....thanks for the pictures.
Moparlee
Page 2 of 3 1 2 3
