Re: Any finished Dakota swap pictures?
[Re: Flipper1938]
#131065
10/02/08 10:05 AM
10/02/08 10:05 AM
Posts: 59 Ontario, Canada
dodge41
Ontario, Canada
I can't help with finished pics, but I am working on one right now for a 41 dodge/fargo pick up. It's about 3" wider track width iirc. So far I have the frame shortened, welded back together and strengthened. Hopefully I'll get the cab mounted on the frame before winter, but with hunting season started my truck time has been shortened. Check out this guys web site: http://personal.kitusa.com/stan/A really nice guy too, I've emailled a few questions for him. The rack and pinion was one of the reasons I decided on the Dakota frame. Matt
[Re: Mopar Ron]
#131071
10/03/08 08:24 PM
10/03/08 08:24 PM
Posts: 228 Kentucky
Flipper1938
Kentucky
here is the link to the dakota frame swap, but its not finished yet, the guy it was sold to is letting it sit till he gets some other things finished
LINK: http://rides.webshots.com/album/300985977tszAFe
Yep, I've drooled over those pictures a couple of times. I was hoping there were some other pics out there thta showed a finished project.
[Re: Flipper1938]
#131072
10/03/08 10:54 PM
10/03/08 10:54 PM
Posts: 692 pa
ramman16248
pa
Here is one a friend of mine did. It has air ride on it as well. It was a total Dakota frame and driveline. He claims it was a fairly simple, (Not quick), project. I have a better picture, I will try to find it!!!! (The purple one)
[Re: ramman16248]
#131073
10/03/08 11:04 PM
10/03/08 11:04 PM
Posts: 692 pa
ramman16248
pa
[Re: ramman16248]
#131074
10/03/08 11:05 PM
10/03/08 11:05 PM
Posts: 692 pa
ramman16248
pa
[Re: ramman16248]
#131075
10/04/08 10:22 AM
10/04/08 10:22 AM
Posts: 228 Kentucky
Flipper1938
Kentucky
Thanks! Tell your friend he has a nice car.
The wheels look like they have a very shallow dish (like a FWD car). Are they really offset like a FWD car, or is it just the style of the wheel?
[Re: Flipper1938]
#131077
10/05/08 10:50 PM
10/05/08 10:50 PM
Posts: 692 pa
ramman16248
pa
They are a very shallow dish. He used everything Dakota underneath.(If you look closely, the wheels are even still 6 bolt hole.)
[Re: 75DART440]
#131080
10/27/08 08:21 PM
10/27/08 08:21 PM
Posts: 3,922 n.e. pa.
65rbdodge
n.e. pa.
not sure about widths, but the 87-90 Dakota uses 5 lug, 4 and a half bolt circle, just like the muscle years. Would think this would make for better, easier wheel selection. Have an 89 shortbed that is going to find itself under a 47 Dodge sedan when I get a little time
i`ve heard that the first generation rotors will swap on the second gen. dakotas
[Re: 65rbdodge]
#131081
11/04/08 02:49 AM
11/04/08 02:49 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
there is aslo a dodge van rotor 5 lug that wil interchange with the dakota 6 lug
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: Flipper1938]
#131083
09/20/10 12:48 AM
09/20/10 12:48 AM
Posts: 106 Oakbank, MB Canada
mbmopar
Oakbank, MB Canada
here is a pic from my unfinished build, 1955 Dodge 1/2 ton with a 90 Dakota ext cab frame.....just to show the front wheels fit in the front fenders, haven't mounted the box yeat, and there will be a MINOR amount of adjustment required, but this is very close to fit.
the rims are the stock dakota, just there for rolling it. the engine will be a 72 440 built, with a 72 torqueflite converted to pushbutton shift, using a 57 truck shifter assy.
"Put a Dodge in your garage!"
