RV Transmission into Cuda questions #1310787
09/25/12 11:22 PM
09/25/12 11:22 PM
CA, USA
buddydog Offline OP
buddydog  Offline OP
CA, USA
So I'm thinking I need a different transmission but has anyone got one of these shorty RV styles to fit under the E-Body tunnel without crazy modifications? Mine has a brake attachment on the upper right side that isn't going in, no way no how! The real question is, can that be modified or should I just start from scratch? I know the driveshaft is an issue, but I need to fab on anyways so that can be a custom length.
Thanks in advance,
Geoff
Re: RV Transmission into Cuda questions [Re: buddydog] #1310788
09/26/12 01:39 AM
09/26/12 01:39 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The mount is in a different place & bolts on different
Scratchnfortraction can give you some idea on that he did it in a truck
