Page 1 of 5 1 2 3 4 5
Sleeper going to T&T tomorrow. (WITH VIDEO!!!!) #1310684
09/25/12 10:56 PM
09/25/12 10:56 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Well... after nearly 2 years, my junk is finally ready for it's first passes tomorrow. Looks like the weather is going to hold out, so I'm off to Milan to make some runs.
Few carb tweaks in the morning, and I should be ready to go.
So what do you guys think? Here is the combo...
-All steel, full interior, '62 Plymouth Savoy 4-door (3700lbs with me in it?)
-8 3/4, with a 2.76 gear and a posi
-255/60 M/T Drag Radials
-Old mystery SS style springs with Rancho 9-ways
-727, 9.5" PTC converter, with a trans brake. ~4700 stall under power
-360", 9.2:1, bowl ported '308 castings, 2.02/1.60 valves
-224/218@.050 cam, .500"/.500" on a 114LSA
-750HP carb, converted for E85, sitting on an old torquer 340 intake
Oh yeah... and a Borg Warner S475 (75mm/96mm) turbo, with a 1.32 A/R
I'll probably just foot brake it tomorrow, and run it off the WG spring which is around 8~9psi or so. I don't want to break it the first time out... lol
So what do you guys think? I personally think a lot will have to do with how good it hooks. I'm fairly confident that it'll MPH, but the ET is a bit of an unknown.
We'll see tomorrow!
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310685
09/25/12 11:07 PM
09/25/12 11:07 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My guess isn't an educated one, just a guess, but I will say 12.50 at 116
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310686
09/25/12 11:07 PM
09/25/12 11:07 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
11.26 @ 125. Good luck!
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310687
09/26/12 12:45 AM
09/26/12 12:45 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
mid to low 12's
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310688
09/26/12 01:01 AM
09/26/12 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Scott if you can get it off the line and out to maybe
100 feet then it'll run a 10.50.... but I really wonder
about hooking that up... if they glue the track(unlikely
on a TNT night)
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: MR_P_BODY] #1310689
09/26/12 01:31 AM
09/26/12 01:31 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Low 11's, spinning down the track.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: DemonDust] #1310690
09/26/12 09:59 AM
09/26/12 09:59 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I was hoping to make it out tonight, but I think something may have come up...was looking forward to seeing this thing in action!
I'm guessing 11.7x at 12x spinning
Good luck!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: OUTLAWD] #1310691
09/26/12 11:41 AM
09/26/12 11:41 AM
Out West
408strokerdart Offline
Out West
12.20 @ 116+. Should MPH good with those gears and boost.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310692
09/26/12 11:57 AM
09/26/12 11:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Scott... what did you do for a hood.... a little hammer
forming to get it back on or will this be a no hood day
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Twin Turbo Mower] #1310693
09/26/12 01:12 PM
09/26/12 01:12 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Rear gear is going to kill it...I say 12.8-12.9
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: MR_P_BODY] #1310694
09/26/12 01:49 PM
09/26/12 01:49 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
No hood for this time out.
BTW... if it doesn't go in the 11's, I'll leave it there for one of you guys to pick up...before the scrap yard gets it... lol
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310695
09/26/12 02:52 PM
09/26/12 02:52 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
First outings are often more sobering that most figure on.
1.41 best 60 foot
6.56 at 104.17
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Blusmbl] #1310696
09/26/12 03:05 PM
09/26/12 03:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not a chance. I like the car but lets get real. I'll say maybe 12.50's. I susspect you might be in the high 12's low 13's. You need more gear, not sure how the 4700 stall and turbo is going to act w/ those 2.76 gears. This is basically a mild SB w/ boost. So you might be able to pick up a second off a N/A SB w/ the same build. I had the same basica build w/ a 440, execpt I had headers and 3.91's. With 6psi of boost I knocked almost a second off the et. 12.90 @ 103 to 12.08 @ 114. With 8 It would have probably ran 11.70-80's. I think his main set back is going to be the gearing, good luck and let us know how it runs w/ video of course.
Coming soon!!!!
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310697
09/26/12 03:07 PM
09/26/12 03:07 PM
Renton Washington
Triple Threat Offline
Renton Washington
It should go 11's pretty easy, if it doesn't it will be because of traction, not lack of power or gearing. We went faster with less in my brothers turbo deal. The T6 frame turbo should move plenty of air to get the job done.
Good luck with it! Should surprise some people.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310698
09/26/12 04:13 PM
09/26/12 04:13 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I've got a smaller cam in my mild NA built 360, ported J heads, stock converter, shift kitted 727, 3.23's and 26" tall tire. Yes its in an Abody, but I race with tools, etc in the car, so I am probably 200# lighter race weight (milan never has the scales on it seems), and run 13.0's in OK air with a best of 12.75 down a mineshaft...from what you've said about it, it pulls harder than a 13 second car...
if you can build boost and get the converter to come up a bit, it will help a TON on the launch..
BTW...kinda killing the sleeper image running with no hood...everyone is gonna see the goods!
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: OUTLAWD] #1310699
09/26/12 05:27 PM
09/26/12 05:27 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Take into consideration that he is making over 600 hp at the motor. So figure from there and take away some for the gear and see what you come up with.
JAKES AUTOMOTIVE
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: JAKE68] #1310700
09/26/12 05:50 PM
09/26/12 05:50 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I got a 68 charger with a mild stroked 360 (406) edel 800 carb. with 2.94 gears in it. It has a tci 2200 stall which helps me get out of the gate.
Took it to the track once and ran a 13.28, 100 mph using only 1st. and 2nd. gear.
So I would say that he should be able to get into the 11's with his combo, but I think the stall is way to high.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: JAKE68] #1310701
09/26/12 06:35 PM
09/26/12 06:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Sorry I don't see how that motor is making 600hp. Not at 8 psi of boost anyway. If that were the case a person could boost a 400hp mild BB and make 700... That combo w/o boost might make 375 so I'll add 100 for the boost. For 11's he'll need 425 at the rear wheels so figure 510+ at the crank. He has to much converter and not enough gear.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310702
09/26/12 06:40 PM
09/26/12 06:40 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
This thing had been dynoed and made like 470 at the rear tires, so doing the math not like is real accurate is making around 600+.
JAKES AUTOMOTIVE
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310703
09/26/12 06:49 PM
09/26/12 06:49 PM
Renton Washington
Renton Washington
375HP N/A
8# of boost is basically 55% of an atmosphere, 61% if at 9 pounds. We'll take the lower of the 2.
375*1.55 = 581hp theoretically. You said he only needs 510?
Keep in mind this a turbo car, not a super charged car, once its spooled, it's at max boost, gears don't mean much, it actually helps to create a load and spool the turbo faster. He has a brake, and should be launching with boost already built. Its a fairly decent sized turbo, and will move a good amount of air. Now if it was a tiny turbo at 8#, it wouldn't move as much air, and wouldn't make as much power. Thats why the above formula is simply a rule of thumb.
-Dustin
