Page 1 of 3 1 2 3
Any finished Dakota swap pictures? #131064
10/02/08 08:05 AM
10/02/08 08:05 AM
Kentucky
Flipper1938 Offline OP
Kentucky
I know a lot of people say they are gonna swap in a Dakota frame or front end. Has anybody got pictures of a finished vehicle? (41 Dodge truck pictures would be especially nice)
I get the feeling the Dakota is a little too wide.
Has anybody narrowed a Dakota front? Seems like the rack and pinion would make things easier.
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131065
10/02/08 10:05 AM
10/02/08 10:05 AM
Ontario, Canada
dodge41 Offline
dodge41  Offline
Ontario, Canada
I can't help with finished pics, but I am working on one right now for a 41 dodge/fargo pick up. It's about 3" wider track width iirc. So far I have the frame shortened, welded back together and strengthened. Hopefully I'll get the cab mounted on the frame before winter, but with hunting season started my truck time has been shortened. Check out this guys web site:
http://personal.kitusa.com/stan/
A really nice guy too, I've emailled a few questions for him. The rack and pinion was one of the reasons I decided on the Dakota frame.
Matt
Re: Any finished Dakota swap pictures? [Re: dodge41] #131066
10/02/08 11:23 AM
10/02/08 11:23 AM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
I did one in my 49 dodge.
Re: Any finished Dakota swap pictures? [Re: 49wayfarer] #131067
10/03/08 07:48 AM
10/03/08 07:48 AM
Kentucky
Kentucky
Do you have any pictures of the finished product?
I'm more interested in how the wheels fit in the fenders and the ride height of the finished truck/car.
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131068
10/03/08 08:59 AM
10/03/08 08:59 AM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
I can't tell you what the ride height is because I don't have the engine in. I am probably going to cut a coil, since I want it lowered. The outside width is about 1" total wider, no problem with tire clearance under those big fenders.
Re: Any finished Dakota swap pictures? [Re: 49wayfarer] #131069
10/03/08 10:32 AM
10/03/08 10:32 AM
Ontario, Canada
dodge41 Offline
dodge41  Offline
Ontario, Canada
The ride height is another reason I went with a dakota frame (instead of volary/diplomat). It's easy to find lowering parts for the front, ie, spindles, springs. And the rear end is easy to adjust with blocks since the dif is already on top of the springs. You can also get the height close to what you want when you mount the cab and front clip by the brackets you make and their height location.
Moparron also has a link to a bunch of pictures of a friend of his' truck that has a dakota frame under it.
Matt
Re: Any finished Dakota swap pictures? [Re: dodge41] #131070
10/03/08 11:00 AM
10/03/08 11:00 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
here is the link to the dakota frame swap, but its not finished yet, the guy it was sold to is letting it sit till he gets some other things finished
LINK:
http://rides.webshots.com/album/300985977tszAFe
Re: Any finished Dakota swap pictures? [Re: Mopar Ron] #131071
10/03/08 08:24 PM
10/03/08 08:24 PM
Kentucky
Kentucky
LINK:
Yep, I've drooled over those pictures a couple of times. I was hoping there were some other pics out there thta showed a finished project.
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131072
10/03/08 10:54 PM
10/03/08 10:54 PM
pa
ramman16248 Offline
ramman16248  Offline
pa
Here is one a friend of mine did. It has air ride on it as well. It was a total Dakota frame and driveline. He claims it was a fairly simple, (Not quick), project. I have a better picture, I will try to find it!!!! (The purple one)
Re: Any finished Dakota swap pictures? [Re: ramman16248] #131073
10/03/08 11:04 PM
10/03/08 11:04 PM
pa
ramman16248 Offline
ramman16248  Offline
pa
Found them!!!!
Re: Any finished Dakota swap pictures? [Re: ramman16248] #131074
10/03/08 11:05 PM
10/03/08 11:05 PM
pa
ramman16248 Offline
ramman16248  Offline
pa
rear shot
Re: Any finished Dakota swap pictures? [Re: ramman16248] #131075
10/04/08 10:22 AM
10/04/08 10:22 AM
Kentucky
Kentucky
Thanks! Tell your friend he has a nice car.
The wheels look like they have a very shallow dish (like a FWD car). Are they really offset like a FWD car, or is it just the style of the wheel?
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131076
10/04/08 11:24 PM
10/04/08 11:24 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Though those are aftermarket wheels, even the stock Dakota wheels have the shallow look. The wheels are actually just about centered over the ball joints. My Dakota has the factory 15x 6 steel wheels and they look about the same offset as the ones pictured on that nice coupe. Gene
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131077
10/05/08 10:50 PM
10/05/08 10:50 PM
pa
ramman16248 Offline
ramman16248  Offline
pa
They are a very shallow dish. He used everything Dakota underneath.(If you look closely, the wheels are even still 6 bolt hole.)
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131078
10/15/08 10:20 PM
10/15/08 10:20 PM
Kentucky
Kentucky
Are all Dakotas the same width?
If not, which model years fall into which width categories?
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131079
10/27/08 12:38 AM
10/27/08 12:38 AM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
not sure about widths, but the 87-90 Dakota uses 5 lug, 4 and a half bolt circle, just like the muscle years. Would think this would make for better, easier wheel selection. Have an 89 shortbed that is going to find itself under a 47 Dodge sedan when I get a little time
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: Any finished Dakota swap pictures? [Re: 75DART440] #131080
10/27/08 08:21 PM
10/27/08 08:21 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i`ve heard that the first generation rotors will swap on the second gen. dakotas
Re: Any finished Dakota swap pictures? [Re: 65rbdodge] #131081
11/04/08 02:49 AM
11/04/08 02:49 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
there is aslo a dodge van rotor 5 lug that wil interchange with the dakota 6 lug
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Any finished Dakota swap pictures? [Re: fstfish66] #131082
11/04/08 12:11 PM
11/04/08 12:11 PM
Kentucky
Kentucky
Six lug wheels aren't a big deal for me. I found a cool set in the six lug dakota pattern.
I was curious about the actual frame/suspension dimensions.
When they went away from the boxy look, there were some magazine articles that said it was still the same truck underneath. I'm wondering how acurate those comments actually were.
Re: Any finished Dakota swap pictures? [Re: Flipper1938] #131083
09/20/10 12:48 AM
09/20/10 12:48 AM
Oakbank, MB Canada
mbmopar Offline
mbmopar  Offline
Oakbank, MB Canada
here is a pic from my unfinished build, 1955 Dodge 1/2 ton with a 90 Dakota ext cab frame.....just to show the front wheels fit in the front fenders, haven't mounted the box yeat, and there will be a MINOR amount of adjustment required, but this is very close to fit.
the rims are the stock dakota, just there for rolling it. the engine will be a 72 440 built, with a 72 torqueflite converted to pushbutton shift, using a 57 truck shifter assy.
"Put a Dodge in your garage!"
Page 1 of 3 1 2 3
