572 hemi i need thicker intake gaskets ? #1310554
09/25/12 07:26 PM
09/25/12 07:26 PM
Maryville TN
68528hemi Offline OP
Maryville TN
i have a little play with the standard gaskets. I i'm using a new mopar cross ram intake with cast iron heads any suggestions. It has been four years since i started saveing money for this build i can not sleep at night knowing how close i'm to finshing.
Re: 572 hemi i need thicker intake gaskets ? [Re: 68528hemi] #1310555
09/25/12 08:23 PM
09/25/12 08:23 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
I have stacked a pair to get the proper thickness to seal the intake with no problems. I know the wedge gaskets come in different thickness and you can get very close to the thickness you want by stacking 2 together.Good luck
Re: 572 hemi i need thicker intake gaskets ? [Re: hankcrank] #1310556
09/25/12 09:07 PM
09/25/12 09:07 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Mr. Gasket makes several thicknesses, they should have what you need. Dave
Re: 572 hemi i need thicker intake gaskets ? [Re: quickd100] #1310557
09/25/12 10:30 PM
09/25/12 10:30 PM
Maryville TN
Maryville TN
thanks i'll give summit a call.
Re: 572 hemi i need thicker intake gaskets ? [Re: 68528hemi] #1310558
09/25/12 10:40 PM
09/25/12 10:40 PM
tn
robnbird Offline
robnbird  Offline
tn
You will get there just don't do anything you will regret.. call Todd Marsh at Marsh Performance her can help you out.
Re: 572 hemi i need thicker intake gaskets ? [Re: 68528hemi] #1310559
09/26/12 02:25 PM
09/26/12 02:25 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
.060" thick is standard, but you can get .090" and .125" thick gaskets. Think I got mine from Mancini Racing...they keep all that stuff in stock usually.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 572 hemi i need thicker intake gaskets ? [Re: 68528hemi] #1310560
09/26/12 06:05 PM
09/26/12 06:05 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Sam
Have you tightened the intake down or just setting it in place with the gaskets on there. Is the intake end rail touching the block or do you have plenty of space there? Are you using the cork gaskets supplied with the intake gaskets for the end rails?
Pictures or it don't count.
Give me a call if I can help any.
Jerry
Old Geezer Racing
Re: 572 hemi i need thicker intake gaskets ? [Re: SCATPACK 1] #1310561
09/26/12 09:19 PM
09/26/12 09:19 PM
Maryville TN
Maryville TN
hi jerry neil said i needed 1/8 inch gaskets found some threw mrgasket. Maybe i can get this thing running by the weekend on a engine break in stand i made should come by and see it.
Re: 572 hemi i need thicker intake gaskets ? [Re: 68528hemi] #1310562
09/26/12 11:04 PM
09/26/12 11:04 PM
tn
robnbird Offline
robnbird  Offline
tn
