Re: When is it time to change my valve springs?
[Re: rebel]
#1309667
09/24/12 02:03 AM
09/24/12 02:03 AM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
other than a pressure test which is the standard way to tell, it's usually once the valve float from a soft spring has worn away the keeper groove on your valve stem & the valve has fallen into the piston! ask me how i know.
Yeeaahh...that's not cool...
[Re: 72demon416]
#1309669
09/24/12 09:25 AM
09/24/12 09:25 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
One other method of checking and storage - There are tools (moroso?)available that hook onto the rocker arm and use a torque wrench to test with. I use one to check mine, and it reads about 280 inch lbs = 320 lbs pressure. If you have a known spring, you can get a reading from it and compare to the others. For the winter just pull the rockers after fogging the motor.
[Re: 72demon416]
#1309671
09/24/12 11:47 AM
09/24/12 11:47 AM
Posts: 4,209 New York
polyspheric
New York
1. free length changes on only some springs 2. some springs are slightly bowed 3. fret marks on the spring seat
Boffin Emeritus
