Page 2 of 3 1 2 3
Re: Homebrew cold air intake using dual snorkel [Re: Pacnorthcuda] #130923
10/08/08 05:11 PM
10/08/08 05:11 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
These cold air setups don't get above the boundry layer of air moving over the skin of the hood. So they have no effect on engine performance. You need to get above the boundry layer to get any noticeable effects.
The cowl induction hood uses the difference in pressure at the bottom of the windshield to get cold air effects. And the 69 A12 car's scoops just barely got into it.
Ryan
Re: Homebrew cold air intake using dual snorkel [Re: Fury Fan] #130924
10/08/08 05:11 PM
10/08/08 05:11 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
http://www.ramairbox.com/
my old one I had on a Ram truck ..
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: Homebrew cold air intake using dual snorkel [Re: Fury Fan] #130925
10/08/08 05:13 PM
10/08/08 05:13 PM
Remember, the late 70s aircleaners are set up for 3" flex tube already, so get 2 of them and put the snorkel from one onto the other. I did that with my 77 Cordoba when I was 17 (gosh, 20 years ago!).
Didn't notice any performance improvememnt, but there are lots of jetting, etc variables to investigate (which I didn't know how to do back then).
There’s an Aussie magazine website that did some investigating on this regarding using a pressure gauge and tubing at the front of the car to determine optimum placement of scoops. Do a search for ‘negative pressure supercharging’ or something like that.
high pressure always seeks a low pressure "out". there is a tremendous amount of
high pressure at the base of the windshield. there is also a tremendous amount
of low pressure inside the air cleaner assembly. the high pressure rushes in to fill
the void, thus causing a "ram" effect. thats why cowl induction hood are so effective
when sealed to the hood. with jetting/timing etc, i've seen greater then a 1/2sec
improvement using this setup. very effective to say the least.
Re: Homebrew cold air intake using dual snorkel [Re: Devil] #130926
10/09/08 10:12 AM
10/09/08 10:12 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Ryan
Who cares about a boundry layer when your grabbing cold air from the front side of the radiator support? Wish I had a picture but I don't. My .25 second improvement was from both COLD air AND RAM air at speed. And I think the Ram air had the bigger effect--due to the gluteus maximus dyno feeling once I reached about 70.
But the dragstrip clock proved the performance increase...over and over.
If you don't mind the look, it can be very effective. The cowl induction setups I think would have a much lesser improvement
Re: Homebrew cold air intake using dual snorkel [Re: Pacnorthcuda] #130927
10/09/08 10:30 AM
10/09/08 10:30 AM
not true. boundry bleedoff layer scoops are only as effective as to how the
air is coming off the front end of a vehicle. u have to experiment or use
a windtunnel to find the optimum height. whereas the cowl style hood feeds
from the highpressure zone at the base of the windshield. something thats
always there and consistant no matter the aerodynamics of the vehicle.
Re: Homebrew cold air intake using dual snorkel #130928
10/09/08 10:39 AM
10/09/08 10:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
much more air is shoved thru the grill of these brick cars than passes over the hood. Most of the old SS cars used the headlight bucket to direct the air into the carb(s) I plan on something similar on my 70 by flipping up one headlight door and jamming all that air into the carb(s) probably gona run a 6-pack. Reguardless it will be better than all the hot air stuck under the hood.
Re: Homebrew cold air intake using dual snorkel [Re: Mr.Yuck] #130929
10/09/08 10:44 AM
10/09/08 10:44 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not a mopar but you get the point. notice the hood scoop isn't even attach to the carb..it's more for clearance and heat exchange
Re: Homebrew cold air intake using dual snorkel [Re: Mr.Yuck] #130930
10/09/08 10:47 AM
10/09/08 10:47 AM
70duster340 Offline
70duster340  Offline
I don't mean to hijack this post, but something I gotta ask. If the ram air thing works as does the cold air intake, then why do these aftermarket companies sell what they call cold air intakes that are really just open air elements that are open under the hood? Won't those so-called cold air intakes just pull in the hot air from under the hood? I would think that in this case, the factory intakes would outperform these aftermarket systems, wouldn't they?
Re: Homebrew cold air intake using dual snorkel [Re: 70duster340] #130931
10/09/08 10:53 AM
10/09/08 10:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Some aftermarket kits do go thru the core support of thru the fender. Most newer cars do pull in outside air. My 95 Dakota has duct work from the grill to the air cleaner assembly. Thus it'd be cool-air. I yanked the plastic piece the place in front of it (I guess to keep big items out) and ran a larger element.
Re: Homebrew cold air intake using dual snorkel [Re: Mr.Yuck] #130932
10/09/08 11:01 AM
10/09/08 11:01 AM
70duster340 Offline
70duster340  Offline
I agree with ya, swingin', but there are some kits out there that are just an open box with a cone style filter attached that claim to be a cold air induction to replace the stock unit. This is on newer vehicles. I have always wondered how they can claim that it pulls in cold air if it's pulling in hot air from under the hood.
Re: Homebrew cold air intake using dual snorkel [Re: 70duster340] #130933
10/09/08 11:13 AM
10/09/08 11:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Dust, yeah I would not consider that "cold air"
Re: Homebrew cold air intake using dual snorkel [Re: Mr.Yuck] #130934
10/09/08 11:29 AM
10/09/08 11:29 AM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
Few aftermarket kits are deisgned to acutally place the filter in an area where there is "cold air". But, having installed a couple of these, from real kits to DIY, the main thing you get is a much better sound from the engine under full throttle.
The typical airbox in a newer car is designed to eliminate intake noise. Adding the cold air kit (at least on v8 cars) brings it closer to the whoosh sound you get when you step into the 4bbls on our Mopars.
I wouldn't personally spend $250 just to make the car sound cooler under WOT, but I have no problem spending $1 on a piece of PVC, and $40 on a K&N cone filter to get the sound.
Re: Homebrew cold air intake using dual snorkel [Re: 70duster340] #130935
10/09/08 02:02 PM
10/09/08 02:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Need more ideas where to actually draw in cool, outside air from. I know on my satellite, the only place I can see is the block off plates in the inner fender wells. Downside to hooking up there is the air inlet tube would have to run right over the exhaust header, and it would be sucking air right in from the side of the tires. High pressure zone down there, so that's good, but also might make the engine suck up water on wet days?
Because those kits are the biggest joke in automotive history. And the fact that so many people pay 200-300 bucks for these kits is mind boggling!
Re: Homebrew cold air intake using dual snorkel [Re: DaytonaTurbo] #130936
10/09/08 02:08 PM
10/09/08 02:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you would just have to make another bend and carry the vent futher forward..
Re: Homebrew cold air intake using dual snorkel [Re: Mr.Yuck] #130937
10/09/08 02:39 PM
10/09/08 02:39 PM
Manitoba, Canada
Manitoba, Canada
Yeah but to where? I'm not really in love with the idea of cutting holes in my inner fenders to draw in air.
Re: Homebrew cold air intake using dual snorkel [Re: DaytonaTurbo] #130938
10/09/08 02:51 PM
10/09/08 02:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no just instead of leaving it draw from the hole turn it slightly forward w/ a slight slant cut towards the top. That should help w/ the H2O.
Re: Homebrew cold air intake using dual snorkel [Re: Mr.Yuck] #130939
10/09/08 02:58 PM
10/09/08 02:58 PM
Manitoba, Canada
Manitoba, Canada
Yeah that's what I was thinking, I could make a little scoop down there to keep water out. Just so long as the head from the headers don't kill the gains by sucking air out from the tires!
Re: Homebrew cold air intake using dual snorkel [Re: 68Bullit] #130940
10/11/08 01:58 PM
10/11/08 01:58 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
From "Terror of I-696," by Nick Brunt,
Mopar Action, October 1993:
Tom Hoover had bought the Coronet brand new, specing it out with the
new-for-'66 Street Hemi and TorqueFlite trans.
snip
Probably the trickest setup on the car was Hoover's homemade hidden ram air
system....[wind tunnel] tests indicated that the inner headlight was the area
of highest pressure. But removing the headlight would have destroyed the car's
stock appearance. After all, he could have just used a hood scoop.
Re: Homebrew cold air intake using dual snorkel [Re: 360view] #130941
10/11/08 02:01 PM
10/11/08 02:01 PM
USA
3
360view Offline
360view  Offline
3
USA
Be sure to measure whatever you build.
All is takes is a length of clear plastic tubing and some water to make a manometer.
An old post of mine:
Heard of the 'Ram Air' effect where the speed of the air hitting the vehicle
builds up pressure in a forward facing air duct and helps 'supercharge' your
engine a bit. ?
Well, at 'typical' street speeds the effect is very very small.
The formula for that is:
Inches of water pressure from Ram Air = (mph) times (mph) divided by 2025.
So at 70 mph the ram air effect is:
(70 mph) times (70 mph) divided by 2025 = 2.4 inches of water.
So the very best possible air inlet tube designed for Ram Air would actually
have a positive pressure of 2.4 inches of water.
How much pressure is an inch of water ?
One psi of pressure is equal to about 28 inches of water.
You can get this by dividing the cubic inches in one cubic foot ( 12 x 12 x
12 ) by the weight of one cubic foot of water ( 62.4 lbs).
The air pressure around us is averages about 14.5 psi at typical heights above
sea level.
So another way of looking at it is that the air pressure around us is about
400 inches of water. ( 14.5 x 28).
So the best Ram Air system at 70 mph gives you a boost of about 2/400 or one
half of one percent.
Small.
Ram air started in airplanes where it means more.
An airplane going 300 mph
gets a boost of:
300 x 300 divided by 2025 = 44 inches
This is a percentage boost of 44/400 or about 11%
Want a challenge?
Consider your tires.
Some strange facts:
At 70 mph the center of your tire is moving 70 mph.
The bottom of your tire where it 'grabs' the pavement is moving at 0.1 mph
The top of your tire is moving forward at 140 mph.
If you could put a 'Ram Air' inlet right at the top of the tires (where it is
horribly dirty and wet) you could get a significant air pressure boost.....
Re: Homebrew cold air intake using dual snorkel [Re: mkdart] #130942
10/11/08 07:32 PM
10/11/08 07:32 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Nice work!
Page 2 of 3 1 2 3
