WAY more work than expected............... #1308642
09/22/12 08:14 AM
09/22/12 08:14 AM
State of confusion
Thumperdart Offline OP
State of confusion
I`m STILL working on wiring my heap and I`m sinking fast and my buddy before me butchered up some wiring so now I`m somewhat lost. I`ve got no voltage to the coil now w/the key on, no running lights and who knows what else. Was checking out different on line diagrams but got lost fast. I thaught this would be easy but I`m beyond pissed now...............3 long days later. Gotta figure somethin out before I light this piece on fire...............
Re: WAY more work than expected............... [Re: Thumperdart] #1308643
09/22/12 08:42 AM
09/22/12 08:42 AM
408Dust Offline
408Dust  Offline
Thump, If you do not have any experience in automotive electrical systems then find someone that does.Not being critical just giving advice that will probably save you some money in the long run.
Re: WAY more work than expected............... [Re: 408Dust] #1308644
09/22/12 09:19 AM
09/22/12 09:19 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
put down the torch and step away from the car!!! somtimes it helps to just walk away for a couple of days,when you get back to it youll have a whole new outlook.its not that hard.belive me ,if i can do it so can you.
Re: WAY more work than expected............... [Re: Thumperdart] #1308645
09/22/12 11:13 AM
09/22/12 11:13 AM
Az
Crizila Offline
Crizila  Offline
Az
You are going to have to start with the factory wiring diagram book for your car and go from there. Shouldn't be too hard depending on how many accessories came with your car. A good approach is to start uncluttering things by removing all the wiring that you are sure you won't use. Don't mean this as an insult, but if you have no power to the coil and no headlights, is the battery connected?
Fastest 300
Re: WAY more work than expected............... [Re: Crizila] #1308646
09/22/12 11:20 AM
09/22/12 11:20 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Thump Time to take a step back & a deep breath Relax and look at one run at a time, If you look at the whole picture you will
Re: WAY more work than expected............... [Re: Crizila] #1308647
09/22/12 11:21 AM
09/22/12 11:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I used a factory book to do my Rampage to make sure
which wire is which ... I have a big suspicion you
dont have a hot going to the column/ignition switch
because the running/turn signals and ignition run
from the column
Re: WAY more work than expected............... [Re: Thumperdart] #1308648
09/22/12 11:54 AM
09/22/12 11:54 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
If you have an MSD box, you won't have power to the coil until cranking, the keyed power is sent to the small red wire of the box.
Hang in there.
Re: WAY more work than expected............... [Re: TheBlackCar] #1308649
09/22/12 12:50 PM
09/22/12 12:50 PM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
One thing at a time....don't try to fix multiple problems unless you know they are related.
PM me if you want some phone support and I'll give you my cell number.
As far as having power to the coil with the key on you have to hve the "start" and "run" circuits tied together and powering the MSD "ignition on" (little red wire) as well as having power to the large red wire that is used as the main power feed.
Don't get too mad, once you figure it out you will be good for life because you will have a new set of skills to rely on. Got to get over the summit first and I think you are there man.
Re: WAY more work than expected............... [Re: Jeremiah] #1308650
09/22/12 01:35 PM
09/22/12 01:35 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Good advice. Dom just work out your problems one system at a time.
"Just a Bracket car dressed up like a streetcar"
Re: WAY more work than expected............... [Re: Jeremiah] #1308651
09/22/12 02:08 PM
09/22/12 02:08 PM
State of confusion
State of confusion
Thankxxx guys. The batts hooked up and on, I do have elec. issues anyhow cos the hack I got it from re-wired a bunch of stuff and now that I`m hooking it up properly it`s not responding like it should. I think I figured out the coil deal and after some , I`ll get back at it...........maybe I sound stupid to some of you guys w/my basic questions and that`s fine cos I don`t know everything and don`t mind cos I`m humble and willing to learn instead of pretending to know or paying soeone else to do it for me. I will prevail TODAY! thankxxx again
Re: WAY more work than expected............... [Re: Thumperdart] #1308652
09/22/12 03:42 PM
09/22/12 03:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dom... I like to do 1 circuit at a time... some of them
do interface with another but that is usually 1 or
maybe 2 wires.... for the ignition and the running
lights/turn signals that stuff goes up the column
and there is usually 2 hot leads going up the column
but still the easiest way to to refer back to the book
(wiring diagram)... also make sure you dont have the
4 way flasher on with no flasher in it.. that will
mess you up.... LOL... I know
Re: WAY more work than expected............... [Re: Thumperdart] #1308653
09/22/12 06:21 PM
09/22/12 06:21 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
Hey man I did the same thing ...Ripped all the wiring out of
my truck and started over cos it was such a mess from the previous
owner's.
I used a full time 12 volt source with a switch to
trigger the MSD box .Some times its e-zer to start it hot by
getting it cranking and switch the box on...and fires right up.
Re: WAY more work than expected............... [Re: 87MO DAK] #1308654
09/22/12 06:52 PM
09/22/12 06:52 PM
State of confusion
State of confusion
The pos runs but can`t figure out the running lights and now the tach. My s@#$$y computer won`t let me see wiring diagrams to hook up my shift light and tach together...........really pissed right now and I may have to put it away for a while.........
Re: WAY more work than expected............... [Re: Thumperdart] #1308655
09/22/12 08:48 PM
09/22/12 08:48 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
I gave up trying to save my stock fuse block and just
brought a chassis wiring harness .It was 130 bucks shipped
and is simple/decent grade of wire ,with a fuse block/wire
that is labeled .I haven't hooked it up yet ...but it
seems pretty e-z. If you have a power probe that helps
figuring out circuits fast and easy .I got a cheap one from
Grainger # 1EKN4 .It works great for checking a + OR - circuit,
and can feed 12 volts .
Re: WAY more work than expected............... [Re: Thumperdart] #1308656
09/22/12 09:20 PM
09/22/12 09:20 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
The pos runs but can`t figure out the running lights and now the tach. My [Email]s@#$$y[/Email] computer won`t let me see wiring diagrams to hook up my shift light and tach together...........really pissed right now and I may have to put it away for a while.........
here you go. also just take your time and i know you will get it. tell you what fly me out there and i will rewire your car if you will tune my Holley for me. i fell about tuning carbs like you are with wiring.lol
http://www.mymopar.com/downloads/1971/71DartA.JPG
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: WAY more work than expected............... [Re: mopar65] #1308657
09/22/12 09:22 PM
09/22/12 09:22 PM
mopar65 Offline
mopar65  Offline
second sheet. Mopar65
http://www.mymopar.com/downloads/1971/71DartB.JPG
also this is the charts that i used to wire up my 73 dart.
here is the link to the site that has all the different year cars.
http://www.mymopar.com/index.php?pid=27
Re: WAY more work than expected............... [Re: mopar65] #1308658
09/23/12 04:49 AM
09/23/12 04:49 AM
State of confusion
State of confusion
Thankxxx for all of the tips and help and I finally have it about finished just need to hook up my MSD shift light and calobrate my wideband. Turns out my buddy I got the car from years ago had done some cheezy patch work wireing and by me hooking it up properly it was actually all wrong if that makes sense and I was chaseing my tail for hours not getting too much done and gettin ticked...........not fun. Decided to take Jeremiah up on calling him and he went out of his way to explain the wires their colors and where they`re SUPPOSED to go in the areas I had no power in and sure enuff, I found the mess and re routed the wires as they should be and we`re good to go. Used hardware store strip pannels and seperated grounds from the pos. wires cleaned up a TON of go no where wires and ran new wire from my gauge pannel to the MSD box and only kept the stock wireing I need for head lights,tail lights and blinkers. I soldered and used shrink wrap on every single wire end and what a difference...........can you say BRIGHT LIGHTS............ You guys rock..............peace. Wish I could fly ya out here Bobby.....maybe next time.
Re: WAY more work than expected............... [Re: Thumperdart] #1308659
09/23/12 07:01 PM
09/23/12 07:01 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: WAY more work than expected............... [Re: tex013] #1308660
09/23/12 08:25 PM
09/23/12 08:25 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I made it all work and easy to work on but dang its ugly
Re: WAY more work than expected............... [Re: tex013] #1308661
09/24/12 03:27 AM
09/24/12 03:27 AM
State of confusion
State of confusion
Tex
Guess I spoke too soon............go out to start my car today and no ignition check fuse box and blown fuse..........20+ fuses later and trying every wiring combo my friend and I can think of and still can`t figure it out. Turn key to crank position and fuse blows....I wired it right and now it`s all wrong. There was a problem w/the ign. when I got the car years ago and that explains why he bypassed the ign. switch and ran a remote switch w/activates the msd box THEN you hit the key to start it.........5-days later I`m beat and over this pos for a bit. How would one go about wiring up the ign. switch when many of the wires are gone and why the hell did it run yesturday and not today? Totally baffeling and I guess I realy have to earn this one............later.
