Carb Tags??? #1308620
09/22/12 01:59 AM
09/22/12 01:59 AM
canada
lrtexpress Offline OP
canada
Little clarification please, under stand that first row on carb tag is for application ie) 4742S = 426 1970 Front, what is the breakdown on the next row, first three digits base on 365days????? then the year ( ie 9 equals 1969 ) and what does the largest digit represent( ie 25 or 23)
Re: Carb Tags??? [Re: lrtexpress] #1308621
09/22/12 02:24 AM
09/22/12 02:24 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, for example 2699 = 269th day of '69 = Friday, 9/26/69. Carb foot should be stamped "J 9".
The 2 digit number represents the last 2 digits of the Chrysler part # 3418 525 4742S front all & 3418 523 4745S rear 4-spd.
Re: Carb Tags??? [Re: 6bblgt] #1308622
09/22/12 02:57 AM
09/22/12 02:57 AM
canada
canada
Understand carb stamp is month and year, what determines Tag date???? and if multi carb are tags matched to carb foot stamp ???, install date??assemebly date???
Re: Carb Tags??? [Re: lrtexpress] #1308623
09/22/12 03:00 AM
09/22/12 03:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Most components are "dated" when they are final assembled (the parts not the car).
WAG: Carter AFB carb
The foot is stamped with the date & part number per CARTER's in-house spec..
The tag (with partial part number/carb number/date) is added (at Carter) per customer Chrysler Corp's spec..
Re: Carb Tags??? [Re: lrtexpress] #1308624
09/22/12 05:29 PM
09/22/12 05:29 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The 365 day date will ALWAYS be within the same month as the letter code(month) on the "foot" stamped date on each carb.
