Another 4-wheel disk brake question!
#1308563
09/22/12 12:29 AM
09/22/12 12:29 AM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Hey guys! These disk brake questions sure seem popular in this forum! Here is my turn at getting some help! The brakes on my Super Bee are absolutely terrible. I can not lock the brakes under any circumstances. I have bled and rebled the brakes (pump method, gravity, MityVac) and there does not appear to be any air trapped in the lines. I pulled the master off and re-bench bled it, and there are no air bubbles coming out. No leaks in the lines that I can tell. I have seen Feets' great "Brake Math" thread... I even built a Google spreadsheet for doing the calculations for me, but Im just not sure how to tell if anything is mismatched, even with the numbers that the spreadsheet spits out at me. Here is a rundown of things that I think are related to braking on my car. 69 Super Bee Manual brakes Wilwood 1" master cylinder Wilwood 10.75" front rotor Wilwood Dynalite front calipers - 4 x 1.75" pistons (4.8 square inches) Dr Diff 10.7" rear rotor Dr Diff Ford caliper... ??? piston? Stock manual pedal approx 7:1 ratio * 17x8 front wheels * 18x10 rear wheels Here are the numbers that I get for my front brakes from the Math post. 1" Master Cylinder piston area - .79 square inches Front caliper piston area - 4.8 square inches Master cylinder pressure @ 100 lbs leg force- 891.27 psi Effective radius of rotor - 4.94 square inches Brake torque - 3528.26 Pad movelent @ 1" - 0.0058 Does anything here sound completely mismatched? I know that the front brakes are positively tiny these days, but I would have thought that they should be big enough to stop the car a few times in a hurry. Any help is greatly appreciated! ![](/ubbthreads/images/graemlins/beer.gif)
Paul '69 Super Bee 383 EFI Turbo
Re: Another 4-wheel disk brake question!
[Re: Black_Bee]
#1308566
09/22/12 01:28 AM
09/22/12 01:28 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Not a big fan of the Wilwood master, IMHO I'd swap it out with a factory piece, either a Fenco pn#1523 or Cardone 101523 (Autozone, CarQuest, most parts stores), or napa NAPA TruStop line 10-1523, Summit Racing.com pn# 100-101523...this master has a 1.031 bore, large fluid capacity and proper stroke for a 7:1 pedal ratio....for a manual disc brake system
No mention of whether or not your using a distribution block/ proportioning valve etc,
For your combo, I'd recommend, no proportioning valve, you could use a stock drum/drum distribution block, but remove the residual valve located in the rear line 69 and down factory disc/drum cars, if the car was previously disc/drum (no mention of the cars former factory equip.) if the car was previously drum/drum the distribution valve is fine,...although IMHO I'd eliminate any factory DV/PV I'd tee the front lines directly of the master, and plumb the rear line directly off the master, and test the system (with 2000 psi hyd gauges) to see what the bias/pressure specs are, and determine if you need an adjustable pressure valve in the rear line
Mike
[Re: Black_Bee]
#1308567
09/22/12 03:38 PM
09/22/12 03:38 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
There are a couple different causes for something like this. Before we can even speculate we need to know what the pedal is doing. Is it hard and not moving far or soft and squishing to the floor? If you keep bleeding them looking for an answer it tells me you've got a soft pedal. Assuming that's the case, what kind of calipers do you have out back? I had a never ending soft pedal after a brake swap and it turned out to be a tiny bit of air in the rear calipers. I had already bled the brakes numerous times and never got any air. A close examination showed the rear calipers were mounted in such a way that a tiny bit of air could be trapped. I had to pull them off the mounts, hold them at a funky angle so the bleeder was absolutely the highest point, and gravity bleed them for a few seconds. That's all it took. Yeah, I was a wee bit irritated with myself.
[Re: jcc]
#1308569
09/22/12 05:59 PM
09/22/12 05:59 PM
Black_Bee
BC, Canada
Hey Guys! Thanks for the help so far guys! :-) I see that Dr Diff is saying to use a smaller master, and Dayclona is saying to use a larger one. I do think that using the Wilwood master was a bit of a mistake as it has been quite the pain in the butt. Having said that, it cost enough money that I dont want to just toss it in the trash to try another master, unless Im positive that doing that will cure my troubles. OK, some answers to some questions: - This was originally a 4-wheel drum car. - I am using stock unmodified distribution block. - Have a prop-valve sitting on the shelf, but it currently is not plumbed in. Previously I ran the Wilwood disks and a stock Master with the stock rear drums and I used the PV then. - Pedal is not soft... it just doesnt seem to stop quick enough no matter hard I push on it. I wouldn't really call it terribly hard as it does move some. JCC is correct, I am simply bleeding the brakes because I feel I should be doing something to correct the issue. - Car with me it it weighs somewhere in the 3700-3800 lbs range. Aluminum everything on the engine, aluminum rad, wilwood disks all took a decent amount of weight off, but those large forged wheels added some back on! - Tires are Falken Azenis RT-615Ks... 245-45-17 and 295-40-18. Awesome sticky tire by the way!!! - Pads are unknown compound... stock Wilwood on front and whatever Dr Diff sent in his kit for the rears. Thanks for the help guys! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Black_Bee]
#1308570
09/22/12 06:50 PM
09/22/12 06:50 PM
feets
Senior Management
Senior Management
Irving, TX
I'd look at a smaller MC.
[Re: DoctorDiff]
#1308572
09/23/12 12:27 AM
09/23/12 12:27 AM
Black_Bee
BC, Canada
Hey guys! Ok... So I need a new master. Is there a readily available 15/16" master? I have a 2-bolt adapter for the Wilwood master cylinder. I also have an adjustable pushrod that adjusts to be only as long as a stock pushrod or shorter... Will that be useable with the stock style MC, or would it need to be longer to compensate for the adapter? Thanks for the help! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: DoctorDiff]
#1308574
09/23/12 01:16 AM
09/23/12 01:16 AM
Black_Bee
BC, Canada
Hey DrDiff... I don't believe it's an AR adapter... It came in a kit I got from Magnum Force. I guess that the difference would be the thickness? What is the thickness of the ARadapter so I could measure mine and see if it would work. How much for the 15/16"master from you? Thanks a lot, I really appreciate the help! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Lefty]
#1308577
09/24/12 02:06 PM
09/24/12 02:06 PM
feets
Senior Management
Senior Management
Irving, TX
The 15/16 MC is a pretty good fit for many common brake systems. Not too many guys have mentioned going to a 3/4" MC. That's getting fairly small and pedal travel can become excessive.
Still, if that's what works on your car, go for it.
