Re: which is the best stroker combo [Re: Streetwize] #1308529
09/24/12 07:42 PM
09/24/12 07:42 PM
Ransom Canyon, Texas
Madness Offline
Madness  Offline
Anyone know of a source for a decent 400" block with thick enough cylinder walls to build another 470" stroker? Every block I've checked has at least one cylinder with thin spots. Best one I have is over .200" on all but one major thrust wall, & it checks at .169" before boring. That would leave me about .154". Help!
Re: which is the best stroker combo [Re: Madness] #1308530
09/24/12 08:16 PM
09/24/12 08:16 PM
gregsdart Offline
gregsdart  Offline
Madness
Take the block with the best seven cylinders and sleeve the eighth
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: which is the best stroker combo [Re: gregsdart] #1308531
09/24/12 08:50 PM
09/24/12 08:50 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Madness
X2.
There is nothing wrong with sleeves provided they're done properly. A Hemi racer I know has 8 sleeves in his block -- on pupose.
Re: which is the best stroker combo [Re: 64Post] #1308532
09/24/12 09:01 PM
09/24/12 09:01 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
Madness
X2.
If I was going to sleeve it I would do all 8 on purpose..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: which is the best stroker combo [Re: Madness] #1308533
09/25/12 12:45 AM
09/25/12 12:45 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d run it........my #`s aren`t all that great and I beat the hell out of my heap and have for 13+ years............. If you`re really worried sleeve that hole.........
Re: which is the best stroker combo [Re: Thumperdart] #1308534
09/25/12 01:08 PM
09/25/12 01:08 PM
dogdays Offline
dogdays  Offline
Pick the block with the best 7 holes and sleeve the 8th. What you are finding seems to be very typical for 400 blocks.
Use a quality ductile iron sleeve.
R.
Re: which is the best stroker combo [Re: Madness] #1308535
09/25/12 01:43 PM
09/25/12 01:43 PM
How much power are you wanting to make and is the motor N/A or are you going to use a power adder? If N/A and below 800 HP use the one you have I have several that where close to that thick on the worst cylinders, no problems yet making over 725 HP on both, 845 HP on one IHTHs If you where to sleeve it it would still be thinner when done than it is now
Re: which is the best stroker combo [Re: Cab_Burge] #1308536
09/25/12 03:25 PM
09/25/12 03:25 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Can't you get thicker blanks?
And isn't ductile iron, while thinner at .125", much stronger than cast iron @ .160"?
Re: which is the best stroker combo [Re: 72N96RR] #1308537
09/25/12 10:01 PM
09/25/12 10:01 PM
Central NC
gch Offline
gch  Offline
Central NC
The best stroker combo is the one you already have parts for or the one you can afford.Well matched parts will make any of them run very strong.
