My turn for Pick a cam.. #1308385
09/21/12 07:13 PM
09/21/12 07:13 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Well guys Im getting ready to put a stock stroke 360 together to hold me over till I get more cash for my r3 project.., just need to pick a cam.
-Its has 107 KB pistons at zero deck (havent mocked it up yet)..
-Brodix heads w/ w2 rocker setup, flowed 290 @ .600, milder porting by Hemphill....thats all I remember as the flow sheet is long gone. Comparable to a w2 head. 65 cc chamber
-No power brakes
-stock A body, 3400? full interior
-265drag radials...
-4:56 Dana..
-converter flashes to 4400...10" TCI super street figher
-victor manifold and I have a 950 that I have laying around..
Any suggestions? Some street used is desired, but Im tolerable of a uncivilized grind. Let me know if you need more info.
Re: My turn for Pick a cam.. [Re: Hot 340] #1308386
09/21/12 07:18 PM
09/21/12 07:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
roller or flat tappet??
this would work nice in that
http://www.summitracing.com/parts/CCA-20-635-5/
Re: My turn for Pick a cam.. [Re: Dodgem] #1308387
09/21/12 07:25 PM
09/21/12 07:25 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Opps, sorry! solid flat tappet with 1.5 rockers
Re: My turn for Pick a cam.. [Re: Hot 340] #1308388
09/21/12 07:50 PM
09/21/12 07:50 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Something that makes some steam and has a nice cackle ,like my little bro has in his 360 it's 258/266 on a 108. It is a comp , forget the lift around 600 ish
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: My turn for Pick a cam.. [Re: Hot 340] #1308389
09/21/12 08:02 PM
09/21/12 08:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd call Bullet cams... they make real good power
Re: My turn for Pick a cam.. [Re: Hot 340] #1308390
09/21/12 08:09 PM
09/21/12 08:09 PM
SoCal
Brian Hafliger Offline
SoCal
-No power brakes
-265drag radials...
-4:56 Dana..
Our 251 cam would work well: 251-258@ .050, 108lca and .570-.560 lift.
Brian Hafliger
Re: My turn for Pick a cam.. [Re: Brian Hafliger] #1308391
09/22/12 12:58 PM
09/22/12 12:58 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks for the suggestions guys..gives me something to choose from. I guess this leads me to the next question of why one over the other? Im not real schooled in cam science. What aspects would be desireable for a combination like this?
Re: My turn for Pick a cam.. [Re: Hot 340] #1308392
09/22/12 09:55 PM
09/22/12 09:55 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Re: My turn for Pick a cam.. [Re: Hot 340] #1308393
09/25/12 05:47 PM
09/25/12 05:47 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
one more bump ..
Re: My turn for Pick a cam.. [Re: Hot 340] #1308394
09/25/12 06:08 PM
09/25/12 06:08 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Most catalog grinds are based on stock type engine/cylinder head combinations . Something like you have with a decent set of cylinder heads will really benefit from a fast rate of lift grind. I would use a Hughes 6064 or something similar.
Keith
Re: My turn for Pick a cam.. [Re: Hot 340] #1308395
09/25/12 08:29 PM
09/25/12 08:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Call Hughes Engines.
