Best/Safest Way to Clean Aluminum Intake #1308084
09/21/12 09:07 AM
09/21/12 09:07 AM
MD
floyd Online content OP
floyd  Online Content OP
MD
I want to get an aluminum intake cleaned. What are the best options? Is a hot tank too caustic?
Re: Best/Safest Way to Clean Aluminum Intake [Re: floyd] #1308085
09/21/12 09:12 AM
09/21/12 09:12 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes a true hot tank eats aluminum.
I'd try some cautic cleaner and a pressure washer.
Air conditioner coil cleaner is caustic and will lift the dirt out and then rinse with the pressure washer. Lot's of cleaners out there will etch the aluminum clean.
I don't like bead blasting because the beads/sand can and does lodge into the porous aluminum and will get into the motor when it get's hot.
This stuff does well.
Re: Best/Safest Way to Clean Aluminum Intake [Re: floyd] #1308086
09/21/12 09:21 AM
09/21/12 09:21 AM
MD
MD
I should have mentioned that I need to remove paint as well. Will that work?
Re: Best/Safest Way to Clean Aluminum Intake [Re: floyd] #1308087
09/21/12 09:22 AM
09/21/12 09:22 AM
Cincinnati, Ohio
Cincinnati, Ohio
No but some paint stripper first and a pressure washer will work.
Re: Best/Safest Way to Clean Aluminum Intake [Re: Challenger 1] #1308088
09/21/12 09:34 AM
09/21/12 09:34 AM
MD
MD
Thanks - I'll give it a try
Re: Best/Safest Way to Clean Aluminum Intake [Re: floyd] #1308089
09/21/12 01:13 PM
09/21/12 01:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Best/Safest Way to Clean Aluminum Intake [Re: floyd] #1308090
09/21/12 01:24 PM
09/21/12 01:24 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I use paint stripper first to remove the heavy paint then do a clean up with solvent (gasoline, acetone, thinner, or Simple Green for you tree huggers) then clean it really well with my steam cleaner. Makes them look like new again.
Re: Best/Safest Way to Clean Aluminum Intake [Re: ScottSmith_Harms] #1308091
09/21/12 04:53 PM
09/21/12 04:53 PM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
I use a soda blast, it strips the paint, cleans the aluminum and dissolves in a water rinse.
Re: Best/Safest Way to Clean Aluminum Intake [Re: floyd] #1308092
09/21/12 05:12 PM
09/21/12 05:12 PM
MD
MD
I was going to ask about soda blast - thanks.
Re: Best/Safest Way to Clean Aluminum Intake [Re: Greg Ducato] #1308093
09/21/12 05:40 PM
09/21/12 05:40 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I will double that notion!
What are you working on now Bruce?
Admiration For Multiple Carburetor Vehicles...
Re: Best/Safest Way to Clean Aluminum Intake [Re: Stewpar] #1308094
09/21/12 06:13 PM
09/21/12 06:13 PM
MD
MD
I'm not sure if it qualifies on "working on"
I picked up a hemi manifold a few weeks ago and am considering cleaning it up. The previous owner had sprayed a dull aluminum paint over the original orange.
Re: Best/Safest Way to Clean Aluminum Intake [Re: floyd] #1308095
09/21/12 06:20 PM
09/21/12 06:20 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Now find a motor/car to bolt it on!
Re: Best/Safest Way to Clean Aluminum Intake [Re: Stewpar] #1308096
09/21/12 08:51 PM
09/21/12 08:51 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
how can you clean it installed?mine is a little dirty but im not going to take it off.
Re: Best/Safest Way to Clean Aluminum Intake [Re: mcmopars] #1308097
09/22/12 04:10 PM
09/22/12 04:10 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I found this out by accident. When the motor is hot, spray WD40 on the dirty places. Everything wipes clean with ease.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
