good way to run a 3/8 fuel line?
#1308036
09/21/12 12:14 AM
09/21/12 12:14 AM
Posts: 649 Davis, California, USA
MrBelvedere2
Hi guys, well I have pretty much decided on my fuel issue is I need to run an electric pump with 3/8 fuel line from tank to carb. Unforunately they don't make fuel lines pre-bent for my 1956 Plymouth Belvedere like they do for the muscle cars. I am wondering a nice homebrew method to run a 3/8 hard line from the tank to the carb, don't really want to run a rubber line all the way up. Any suggestions? thanks!
1965 Plymouth Belvedere II hardtop
Re: good way to run a 3/8 fuel line?
[Re: MrBelvedere2]
#1308037
09/21/12 12:29 AM
09/21/12 12:29 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i got a roll of the 3/8 alum. fuel line from summit, and basically started at at the front of the car and ran it along the rail out of the way back to the tank, i got the rubber clamps and clamped it every so often. suggestion, buy a cheap bending tool, will help out with the harder bends, worked great for me, 68'dodge coronet.
[Re: MrBelvedere2]
#1308042
09/21/12 08:58 AM
09/21/12 08:58 AM
Challenger 1
Cincinnati, Ohio
My suggestion is not to use aluminum. It's not made for the street and it will corrod with todays ethanol fuel. Steel is the best to use and not hard at all to work with with the proper bender. Do it right the first time and enjoy the quaility and peace of mind. Might want to read this post about water in gas. web page
[Re: RapidRobert]
#1308045
09/21/12 12:05 PM
09/21/12 12:05 PM
Posts: 416 Franklin Co. Illinois
runinonmt
I used coiled aluminum. Not hard at all to straighten. Just use a flat surface and take your time. I bought a beader(makes the bubble for a line,3/8" is the smallest without buying a very expansive one)from Amazon and the tubing bender from Home Depot. It sounds crazy but fill the tube with sand and plug it for bending. Works great and the bends look better. If you have to cut the line for removal just file a spot so you can line it back up. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
