Piston info! #1306858
09/19/12 01:15 PM
09/19/12 01:15 PM
LaFollette TN 37766
3
383ramd150 Offline OP
LaFollette TN 37766
Hey,Just need some info on a set of pistons I've found for 250 bucks.They are SpeedPro 2293 forged with dome!Any specs would be appreciated!Thanks
Re: Piston info! [Re: 383ramd150] #1306859
09/19/12 02:48 PM
09/19/12 02:48 PM
dogdays Offline
dogdays  Offline
From an Ebay listing:
NEW OLD STOCK TRW FORGED PISTONS.
PART NUMBER L2293F STANDARD BORE.
THEY FIT 383 CHRYSLER
.368 DOME
5/64 5/64 3/16 RING LANDS
1.915 COMPRESSION DISTANCE
12.42 TO 1 WITH 78.5 CC CLOSED CHAMBER HEADS
11.05 TO 1 WITH 88 CC OPEN CHAMBER HEADS.
They have a big dome with a "fire slot" for the spark plug, definitely old technology.
One other thing: They are heavy.
R.
Re: Piston info! [Re: 383ramd150] #1306860
09/19/12 02:49 PM
09/19/12 02:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
heavy forged piston that is called a 12.0 piston in a 383 , but probably closer to 11 depending on the head used .
Keep looking ...
Re: Piston info! [Re: JohnRR] #1306861
09/19/12 03:01 PM
09/19/12 03:01 PM
dogdays Offline
dogdays  Offline
Theoretically, I agree. I'd check Mancini to see if he's got Diamonds on sale. Also, does Probe make a piston?
The 383 should love to rev and if you can take 100 - 150 grams out of each piston it'll live up to its promise. It's worth the extra $. Also, the pistons set up the rest of the engine and they're worth spending more on to get what you NEED.
R.
Re: Piston info! [Re: dogdays] #1306862
09/20/12 01:48 AM
09/20/12 01:48 AM
LaFollette TN 37766
3
LaFollette TN 37766
Ok thanks and i will just keep looking
Re: Piston info! [Re: 383ramd150] #1306863
09/20/12 06:22 PM
09/20/12 06:22 PM
dogdays Offline
dogdays  Offline
Mancini has 4.280" Diamond flattops for 3.75" stroke 6.358 rod 383 blocks for $499. Are you sure you don't want a stroker?
You're only one crank and $249 away!
R.
