Page 5 of 6 1 2 3 4 5 6
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306212
09/19/12 11:16 PM
09/19/12 11:16 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306213
09/19/12 11:18 PM
09/19/12 11:18 PM
Renton Washington
Renton Washington
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306214
09/19/12 11:23 PM
09/19/12 11:23 PM
I think I would contact Manley on that for them to do a failure analysis on that valve
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306215
09/19/12 11:26 PM
09/19/12 11:26 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Looking at the stem you can see very clear indications of crack propagation followed by ductile failure. There may have been a surface defect on the one side that caused it to crack, maybe from machining, etc..
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Kevins493] #1306216
09/20/12 01:16 AM
09/20/12 01:16 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
JB Weld it, you'll be fine...
Seriously, I hate it for ya'. Put out the call for parts if you need some help.
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: ProStock1320] #1306217
09/20/12 01:44 AM
09/20/12 01:44 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
WOW.... So sorry to see this post, Dustin! That sucks! not much more to say.
My first thought: go big block. Build a low-deck 451 or 470. You'll go just as fast, and it'll be more durable. But I also realize you probably have a lot of small block stuff left over that would cut the cost of a new motor...... tough call.
Where's the old 408 these days???
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: StealthWedge67] #1306218
09/20/12 01:58 AM
09/20/12 01:58 AM
Renton Washington
Renton Washington
My thought as well, but I have ZERO big block stuff.
The old engine was a nothing special 340, cast piston, stock rod, stock crank. Its got well over 1000 passes on it and 5 years of abuse. I robbed the heads and other parts out of it to build this engine, so its not ready to go at all. I think its racing days are over, still runs great, but needs to go in a cruiser, not my car..... apparently i'm hard on stuff.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306219
09/20/12 02:33 AM
09/20/12 02:33 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Really sorry to see it, what a mess!!
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: sshemi] #1306220
09/20/12 02:51 AM
09/20/12 02:51 AM
SoCal
Brian Hafliger Offline
SoCal
That really sucks!! Very sorry to see this.
Brian
Brian Hafliger
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Brian Hafliger] #1306221
09/20/12 10:35 AM
09/20/12 10:35 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Is that a solid cam, Sorry Im caching on this late, really sucks for ya.
Was there any signs of valve float?
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Moparnut426] #1306222
09/20/12 12:41 PM
09/20/12 12:41 PM
Renton Washington
Renton Washington
Yep solid cam, 263/268@.050 .... Now its a "3/4 race" cam
No signs of float really, when it got hotter in the summer It would occasionally miss slightly in high gear, that went away as the air got better again.
I'll check that spring for pressure when I get a chance. Not really in the mood to touch it the last couple days.
-Dustin
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306223
09/20/12 01:22 PM
09/20/12 01:22 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I do believe you've got a good shot at winning the winter carnage thread contest.
Yeah, it's got a smallblock.
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: 340B5] #1306224
09/20/12 01:26 PM
09/20/12 01:26 PM
Renton Washington
Renton Washington
For the sake of everyone else here, I sincerely hope I do.
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306225
09/20/12 01:31 PM
09/20/12 01:31 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Seems like it might have been old damage (the small crack) from an older mishap (over reved it maybe caught a piston and tweeked it a bit causing the crack a while ago?) and then it finally let go.
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Kevins493] #1306226
09/20/12 01:58 PM
09/20/12 01:58 PM
NC
440Jim Offline
440Jim  Offline
NC
I think this illustrates what you are saying.
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306227
09/20/12 07:33 PM
09/20/12 07:33 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Definately sukz. The worst I've ever seen, and I've seen a few.
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306228
09/20/12 07:39 PM
09/20/12 07:39 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Too bad you weren't closer. I would work a deal with you on my W2 408 motor. It would be up to the task of 200 passes a year. Just pulled it because the hemi is done. I put about 8 passes on it as it was just built...
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Dragula] #1306229
09/20/12 08:03 PM
09/20/12 08:03 PM
Plant city fl
70Dart499 Offline
70Dart499  Offline
Plant city fl
Man, that sucks, I know how you feel, on my last car, I had a rod break in the lights, and it looked almost that bad!
1970 Dart Drag Car
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: 440Jim] #1306230
09/20/12 09:05 PM
09/20/12 09:05 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Thanks Jim! that does a much better job than my explanation.
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: 70Dart499] #1306231
09/20/12 09:09 PM
09/20/12 09:09 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Its good to see you still have some humor,.... 3/4 cam .....
