Page 6 of 6 1 2 3 4 5 6
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: emarine01] #1306232
09/20/12 10:36 PM
09/20/12 10:36 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Probably won't make you feel better but...
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: dodgeboy11] #1306233
09/21/12 12:19 AM
09/21/12 12:19 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Is that an eagle crank?
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Triple Threat] #1306234
09/21/12 02:43 AM
09/21/12 02:43 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Yep solid cam, 263/268@.050 .... Now its a "3/4 race" cam
That made me laugh.
Hope you can save the head.
"Just a Bracket car dressed up like a streetcar"
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: 440Jim] #1306235
09/21/12 10:59 PM
09/21/12 10:59 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Looking at the stem you can see very clear indications of crack propagation followed by ductile failure. There may have been a surface defect on the one side that caused it to crack, maybe from machining, etc..
I think this illustrates what you are saying.
Yes, that picture pretty much illustrates classic fatigue failure to the point you could put it in a textbook. I had a crankshaft in a Land Rover diesel parts engine that looked just like that. It is remarkable how little metal is needed for the one time load.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: New Worst! Kaboom! [Re: Triple Threat] #1306236
09/22/12 12:19 AM
09/22/12 12:19 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I don't remember what series valve it was off the top of my head, it wasn't top tier but it wasn't bottom shelf either.
Kinda curious about the valve series, as in was it a 1 or 2 piece valve. Many people don't know that there are A LOT of valves made by starting with a seperate stem and head and spinning them in different directions to friction weld the heads on.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: New Worst! Kaboom! [Re: Evil Spirit] #1306237
09/22/12 12:54 AM
09/22/12 12:54 AM
Renton Washington
Triple Threat Offline OP
Renton Washington
Manley "Race Flo"
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: New Worst! Kaboom! [Re: Triple Threat] #1306238
09/22/12 01:19 AM
09/22/12 01:19 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Manley "Race Flo"
The Race Flo series is listed as a 1 piece valve.
Re: New Worst! Kaboom! UPDATE X2 Added pictures of Head [Re: Triple Threat] #1306239
09/26/12 01:33 PM
09/26/12 01:33 PM
Renton Washington
Renton Washington
Head looks like it should easily be fixable!
-Dustin
Re: New Worst! Kaboom! UPDATE X2 Added pictures of Head [Re: Triple Threat] #1306240
09/26/12 01:39 PM
09/26/12 01:39 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Ouch! Man, you don't mess around when you blow something up.
Re: New Worst! Kaboom! UPDATE X2 Added pictures of Head [Re: Triple Threat] #1306241
09/26/12 01:41 PM
09/26/12 01:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No way can you fix that...What a mess...I think you shoud ljust box it up and send it down here, I need something to hold the door open. Shoudl work nicely for that
Re: New Worst! Kaboom! [Re: Triple Threat] #1306242
09/26/12 01:57 PM
09/26/12 01:57 PM
iowa
wesw Offline
wesw  Offline
iowa
That's a lot of scrap iron. Looks like a new power plant is in the works.
598 ci predator
Re: New Worst! Kaboom! [Re: wesw] #1306243
09/27/12 04:31 PM
09/27/12 04:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow sorry to see that. It seems like the only good thing to come out of a blown eng is you will most likely build the next one even stronger. Ron
Re: New Worst! Kaboom! [Re: 383man] #1306244
01/21/13 01:44 AM
01/21/13 01:44 AM
Renton Washington
Renton Washington
Finally pulled it all apart. All the bearings look great it didn't run long enough as it self destructed to hurt anything.
Will mag the crank and see about putting it back together.
Re: New Worst! Kaboom! [Re: Triple Threat] #1306245
01/21/13 01:45 AM
01/21/13 01:45 AM
Renton Washington
Renton Washington
Re: New Worst! Kaboom! [Re: Triple Threat] #1306246
01/21/13 01:47 AM
01/21/13 01:47 AM
Renton Washington
Renton Washington
Re: New Worst! Kaboom! [Re: Triple Threat] #1306247
01/21/13 01:50 AM
01/21/13 01:50 AM
Renton Washington
Renton Washington
last one
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: Cab_Burge] #1306248
01/21/13 03:30 AM
01/21/13 03:30 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
I think I would contact Manley on that for them to do a failure analysis on that valve
Good luck!!! My old boss had the same thing happen on a roundy round motor with one of there valves. He phoned them and explained that it was brand new. It made 1 hot lap and then carnage!!! Manley apologized and sent him a brand new valve!
Re: New Worst! Kaboom! UPDATE Added pictures of Valve [Re: mopartoby] #1306249
01/21/13 04:37 PM
01/21/13 04:37 PM
iowa
rook440 Offline
rook440  Offline
iowa
Im not wild about manley valves ...was very lucky when one broke in my hemi just as I was shutting it off to pull the motor ,,,literally caused no damage ...pulled apart and replaced all the valves ,the old Manley severe duty valves were laying on my bench and i was working on my car then i heard something hit the floor it sounded like a glass breaking ,went to investigate and it was another Manley severe duty valve had rolled off the bench and had shattered ......I still have both of them put away for the doubters ...these valves have a step in them down by the head and both of them broke there ...I was just real lucky ...
