Re: New Worst! Kaboom! UPDATE Added pictures of Valve
[Re: ProStock1320]
#1306217
09/20/12 01:44 AM
09/20/12 01:44 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
WOW.... So sorry to see this post, Dustin! ![](/ubbthreads/images/graemlins/frowwn.gif) That sucks! not much more to say. My first thought: go big block. Build a low-deck 451 or 470. You'll go just as fast, and it'll be more durable. But I also realize you probably have a lot of small block stuff left over that would cut the cost of a new motor...... tough call. Where's the old 408 these days???
[Re: StealthWedge67]
#1306218
09/20/12 01:58 AM
09/20/12 01:58 AM
Triple Threat
Renton Washington
My thought as well, but I have ZERO big block stuff.
The old engine was a nothing special 340, cast piston, stock rod, stock crank. Its got well over 1000 passes on it and 5 years of abuse. I robbed the heads and other parts out of it to build this engine, so its not ready to go at all. I think its racing days are over, still runs great, but needs to go in a cruiser, not my car..... apparently i'm hard on stuff. ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: sshemi]
#1306220
09/20/12 02:51 AM
09/20/12 02:51 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
That really sucks!! Very sorry to see this. Brian
Brian Hafliger
[Re: Moparnut426]
#1306222
09/20/12 12:41 PM
09/20/12 12:41 PM
Triple Threat
Renton Washington
Yep solid cam, 263/268@.050 .... Now its a "3/4 race" cam ![](/ubbthreads/images/graemlins/biggrin.gif) No signs of float really, when it got hotter in the summer It would occasionally miss slightly in high gear, that went away as the air got better again. I'll check that spring for pressure when I get a chance. Not really in the mood to touch it the last couple days.
[Re: Triple Threat]
#1306223
09/20/12 01:22 PM
09/20/12 01:22 PM
Posts: 1,532 off the grid
340B5
off the grid
I do believe you've got a good shot at winning the winter carnage thread contest.
Yeah, it's got a smallblock.
[Re: 340B5]
#1306224
09/20/12 01:26 PM
09/20/12 01:26 PM
Triple Threat
Renton Washington
For the sake of everyone else here, I sincerely hope I do.
[Re: Kevins493]
#1306226
09/20/12 01:58 PM
09/20/12 01:58 PM
Posts: 16,934 NC
440Jim
NC
Looking at the stem you can see very clear indications of crack propagation followed by ductile failure. There may have been a surface defect on the one side that caused it to crack, maybe from machining, etc..
I think this illustrates what you are saying.
[Re: Triple Threat]
#1306228
09/20/12 07:39 PM
09/20/12 07:39 PM
Posts: 12,421 Taxes & Virus's R-US, NY
Dragula
Too bad you weren't closer. I would work a deal with you on my W2 408 motor. It would be up to the task of 200 passes a year. Just pulled it because the hemi is done. I put about 8 passes on it as it was just built...
[Re: 440Jim]
#1306230
09/20/12 09:05 PM
09/20/12 09:05 PM
Posts: 2,379 MD
Kevins493
MD
Thanks Jim! that does a much better job than my explanation. ![](/ubbthreads/images/graemlins/thumbs.gif)
