Re: what causes this
[Re: dartman366]
#1305672
09/17/12 02:11 PM
09/17/12 02:11 PM
dartman366
Mt. Vernon, Ohio
another, sorry bad pics. now that I look at it, it seems to be coming from the squirter,,or both.
[Re: Cab_Burge]
#1305674
09/17/12 02:28 PM
09/17/12 02:28 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
Fuel pullover. The air going past the nozzles will create a pressure drop sometimes great enough to lift the check valve off the seat and pull fuel out.
[Re: Cab_Burge]
#1305675
09/17/12 02:52 PM
09/17/12 02:52 PM
dartman366
Mt. Vernon, Ohio
Air pressue in the carb. at the finish line when you shut the throttle I'm assuming that your not using a air cleaner, yes or no?
nope no air cleaner, just a air box to seal to the hood/scoop.
GJ,I have heard of that happening, but have not noticed this on my car untill here lately. do the anti pullover style squirters really work??
