Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: hemidup] #1305468
10/07/12 09:05 AM
10/07/12 09:05 AM
tboomer Online work OP
tboomer  Online Work OP
Was that the red 64? Jeff...Saw Mike launch with the hoops in the air! Nice car! Another member here won his class,he can tell the story! Low car count due to the cold weather. I got there late,so I bought a card for today. Thanks to everyone for stopping by to sign the banner and thanks Barnstorm for the Hemi sweatshirt!
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: hemidup] #1305469
10/07/12 09:23 AM
10/07/12 09:23 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The plans are for us Iowa boys to keep the money here!! You Minnesota racers are pretty tough to beat!
So far your plan hasn't worked. Congrats to Steve Glubke on winning the Box/No box final today!
Jeff
I'm glad Steve won. He's been hot this year.
Steve lost his wife Teri to cancer this last April, so it's good to see him do well racing.
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: JERICOGTX] #1305470
10/07/12 10:26 AM
10/07/12 10:26 AM
Central Wi.
1965wedge Offline
1965wedge  Offline
Central Wi.
I didn't have a good day. The Coronet caught on fire. I got out alive, with only some burns on my right hand. As far as the car goes, everything from the steering wheel forward is destroyed or damaged. Good thing Wisconsin winters are so long....
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: 1965wedge] #1305471
10/07/12 10:02 PM
10/07/12 10:02 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Well...minus air can have unanticipated problems for some. New HP and less traction. CFR went out of the way to prep the track and keeping everyone informed of the need to limit racing to 1/8 mi on Sat. Maybe Steve Glubke lent his shoe polish marker to all his victims and not just me! Hope to see better posts about Sun.
The little old lady from Pasadena is back!
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: 1965wedge] #1305472
10/13/12 10:22 PM
10/13/12 10:22 PM
Iowa
toolmanmike Offline
toolmanmike  Offline
Iowa
I saw your car after the fire but didn't have the heart to take a photo. Sorry it happened. I did take one earlier though. I posted them on forbodiesonly. Here's my link and a link from alleyoop who took some great starting line shots. Many of your cars are pictured. Mike
http://www.forabodiesonly.com/mopar/showthread.php?t=208332&highlight=mopar+max
http://www.forabodiesonly.com/mopar/showthread.php?t=208573&highlight=mopar+max
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: 1965wedge] #1305473
10/13/12 11:16 PM
10/13/12 11:16 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
seen your post , I'm in central Wi. maybe I can help with your repair or parts.
Russ
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: old_racer] #1305474
10/13/12 11:40 PM
10/13/12 11:40 PM
illinois
moparpiff Offline
moparpiff  Offline
illinois
Glad you guys had a good event again this year. I am not to sure who is in charge of scheduling if it is left up to Dumpster Dan or not but the last 2 years he has asked us MOPAR guys at Cordova, (Cedar Falls sister track) to come up and race this event. We would all be more than willing but the event has been scheduled the same weekend as our last points race at Cordova. If there was anyway for anyone to convince them to try and do the event on an off week for both tracks it would be nice. I talked with Dumpster about this at Oktoberfest this year at Cordova and he said he would see what he could do. Hopefully something could happen to get some alignment between the two tracks to allow for more cars to come to Cedar Falls and up the car count at the Mopar Max event.
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: moparpiff] #1305475
10/14/12 09:35 AM
10/14/12 09:35 AM
I talked to Scott Gardner about the scheduling,too. The week before ET finals,Cordova,CFR,and Eddyville were not running. That date would have been good and it would not interfere with racers going to Monster Mopar.
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: old_racer] #1305476
10/14/12 10:41 AM
10/14/12 10:41 AM
Central Wi.
1965wedge Offline
1965wedge  Offline
Central Wi.
Russ,
Thanks for your concern, maybe we can get together and talk old hot rods. The cards were stacked against me that day. As soon as I noticed the fire, I turned off everything from inside the car. Got out and thought I shut off the master switch. We still do not know what started the fire. After the fire was finally extinguished and things settled down, one of the track guys said that the fuel pump was still running. It didn't make sense as the master switch was turned off. After some investigation we found the contacts in the master welded together and unable to open the circuit. This was caused by the main battery lead having the insulation melted and shorted to ground. The power to the fuel pump is routed in the same harness to the back of the car. The fuel pump power lead then shorted/melted to the main power lead. This made it impossible to shut off the fuel pump without crawling under a burning car and physically unplugging the fuel pump. In the future I will run the power to the fuel pump in its own harness. Hopefully fellow racers who have run the wires together will see this post and isolate the two leads. If other members read this post and know of a way to get this information to the entire site, it could save someone from disaster.
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: 1965wedge] #1305477
10/14/12 12:07 PM
10/14/12 12:07 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
wow what a mess, hopefully after you clean things up there will be alot you can reuse. where are you at, I'm up by Wausau.
Russ
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: old_racer] #1305478
10/14/12 01:15 PM
10/14/12 01:15 PM
Central Wi.
1965wedge Offline
1965wedge  Offline
Central Wi.
Between Plover & Rapids.
Re: Mopar Max II at Cedar Falls Raceway Oct 5-7th!! [Re: 1965wedge] #1305479
10/14/12 04:11 PM
10/14/12 04:11 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
Denny let me know when you are going to start working on it, things are going to slow down at work soon, I can give you a hand. Doug
