Fuel Pump Questions #1304377
09/15/12 07:13 PM
09/15/12 07:13 PM
St. Paul, Mn.
W
ww2 Offline OP
ww2  Offline OP
W
St. Paul, Mn.
Removed the outlet fittings on my mechanical pump and it is obviously siphoning gas from the tank, is this normal? Is there any data out there that says how much gas in ounces should be produced say in 15 seconds during cranking? The pump is a Carter rated at 120 gph.
Re: Fuel Pump Questions [Re: ww2] #1304378
09/16/12 03:15 PM
09/16/12 03:15 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
cranking for about 15 seconds, you should get 10-16 ounces of fuel out of a good pump. roughly 1/3-1/2 quart.
Re: Fuel Pump Questions [Re: ww2] #1304379
09/16/12 04:49 PM
09/16/12 04:49 PM
describe how it is acting
