Looking for 426 Hemi Head Bolts
#1304175
09/15/12 10:26 AM
09/15/12 10:26 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I have a factory 66 Hemi Block and heads. I want to put the heads on but can't find the reasoning in using a $200 arp bolt kit. Does anyone know of anyone who make a factory style head bolt kit. Thanks. fas141@comcast.net
RS23L7 4-Speed
Re: Looking for 426 Hemi Head Bolts
[Re: Mopar_Mike]
#1304180
09/15/12 01:24 PM
09/15/12 01:24 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
If you think the ARP kit is expensive here it your asked for BOLT kit , pry open the wallet wide ...
Mike it's a HEMI , nothing is cheap , haven't you figured that out yet ?
http://www.summitracing.com/parts/DCC-4529978/
Really? just for bolts?? absurd.. I suppose someone will chime in and say they are heated treated in some rare kiln in the Himalayas by a Monk who keeps up on Mopar magazine.. unreal.. thanks, John.
They aren't JUST BOLTS , it's a bolt AND stud kit and they are engineered for the application. I guess you could just go to the hardware store and get grade 8 chinese bolts , tell us how that works out ...
[Re: Mopar_Mike]
#1304183
09/15/12 02:36 PM
09/15/12 02:36 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
fas141@comcast.net
I just dont get it....$200 for a very high quality set of fasteners isnt too much to pay, IMO. They are superior quality to anything that came from the factory. A set of used originals might have been cycled a multitude of times-which will compromise their ability to properly clamp. The nice thing about the Hemi is that the headbolts are all hidden so you dont have to worry about it looking incorrect, either.
Its a no brainer in my book.
MB
[Re: RUNCHARGER]
#1304185
09/15/12 06:50 PM
09/15/12 06:50 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Wow: This is why I don't buy stuff that other people have "rebuilt, restored or repaired". I'm amazed at some of these high dollar paint job show cars that I've witnessed with leaking carbs, unsafe brakes and steering etc. Just to save a few bucks I guess.
Sheldon
Seems like every post on this site now ends with...."on a budget".
Sure everyone has monetary limitations, but i'm in the camp of "do it once and do it right"....
MB
[Re: HemiStan]
#1304187
09/15/12 11:01 PM
09/15/12 11:01 PM
Posts: 2,431 USA
SSAAHemiFan
USA
I went thru the head bolt hassle myself... There are alot of people using aftermarket bolts successfully BUT truthfully the stock bolts are designed to have the proper stretch (preload) and are undercut to allow clearance in the factory casting I had new bolts from Barton that had excessive runout despite returning them 3 times I then purchased some very nice, high quality bolts from FHO. FHO bolts are better suited to aftermarket or newer castings - these have larger bolt openings The FHO bolts were tight around the base on my stock heads which pushed on the casting enough to cause alignment issues. I Could have redrilled all bolt holes for clearance but they were also a tad long for an original block and heads, with a steel shim head gasket. It's a long winded way to say I found some NOS stock bolts instead. The MP ones used to be very poor quality - I haven't seen any in the past 3 years - they may have improved since ? Before I found the Chrysler bolt's I was going to buy them from Arruza Aggrivating but that's what happened to me
