Radiators have 1 core.
Radiator cores have rows of cooling tubes (1, 2, 3, 4, etc.).
The stock '71 b & e-body 318/904 with A/C is a 26" radiator (#3443969) & has 2 or 3 rows
of tubes.
A modern 3-row high fin count or aluminumn radiator should be enough for a mild 360 cruiser. If your engine currently runs hot (high compression/overbore), is used in "extreme" manners (towing/high RPM driving or cruising), with the A/C on (is it still there?), or you just want that extra mental peace - go with the 4-row.
