69 Charger Door Glass problems #1303511
09/13/12 11:07 PM
09/13/12 11:07 PM
Lowell Mi
Rat_Exterminator Offline OP
Lowell Mi
the drivers door glass came off the track, I've pulled the interior panel off and the lift arm appeared to have been to far in towards the seat to line up with the glass. Bent it out a little and it goes up fine but the glass stays up when the operator goes down. there must be more than gravity to pull glass down with the operator but I don't see anything thru the openings. Not sure where my FSM is and I need to have glass up for the Pure Stock Drags in the AM. Thanks Greg
Re: 69 Charger Door Glass problems [Re: Rat_Exterminator] #1303512
09/13/12 11:38 PM
09/13/12 11:38 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
It sounds like you need to put some weatherstripping adhesive in the lift channel to attach the window to the regulator arm/lift bracket thing.
Re: 69 Charger Door Glass problems [Re: Jeremiah] #1303513
09/14/12 12:07 AM
09/14/12 12:07 AM
Lowell Mi
Lowell Mi
Found missing piece that is held in place by white nylon bushing that goes thru the hole in glass. this 2 piece bushing and metal bracket was laying way in the back bottom of the door. it looks like the plastic piece goes in from the outside and then the second half of the plastic piece pushes inside the outer pc, holding it in place. kind of hard to push in from the outside, no access or working room but with a screwdriver handle against it, I think its in as far as it will go. seems to be holding and there is a little klunk as it moves at first but at least it's going up and down now. Thanks Greg
Re: 69 Charger Door Glass problems [Re: Rat_Exterminator] #1303514
09/14/12 12:19 AM
09/14/12 12:19 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What you do to prevent that from happening again is sand down the nylon "pin" that goes through the center of the push in thing so it is a light press fit. Otherwise it might happen again and again, especially if you are hammering on the car. DAMHIK
Re: 69 Charger Door Glass problems [Re: Jeremiah] #1303515
09/14/12 12:38 AM
09/14/12 12:38 AM
Lowell Mi
Lowell Mi
Thanks for the tip Jeremiah, I throw a little sand paper in the glovebox in case it happens again. Greg
Re: 69 Charger Door Glass problems [Re: Rat_Exterminator] #1303516
09/14/12 03:32 AM
09/14/12 03:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
No problem, happy racing!
Re: 69 Charger Door Glass problems [Re: Rat_Exterminator] #1303517
09/14/12 06:17 PM
09/14/12 06:17 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
