Help needed with II gen. Viper motor #1303304
09/13/12 10:26 AM
09/13/12 10:26 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Need some professional help with 2gen. Viper motor. We ordered .010" undersize main bearings. Block is machined ( line honed )and crankshaft is also machined to size 76,00 millimeters ( 2,992" ) like book told.
Fact is that crank is not turning...way too tight. What may cause this and do anyone know what needs to be proper crank main journal size for 0.010" undersize bearings?
Thanks a lot for any help!
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Help needed with II gen. Viper motor [Re: Georg] #1303305
09/13/12 11:38 AM
09/13/12 11:38 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I'm guessing you do not have a dial bore gauge and a micrometer? You just had the work done and bolted it together? If this is true you need to take some measurments to see where the problem lies.
BB, TT5,Procharged 3300lb Street Car 4.79/154
