72 Demon, manual drum brakes.
My master cylinder was leaking from the top. I got a new gasket for it and bent the spring to hold it tighter, but it still leaked.
So I put on a new master cylinder, and it leaked from the top also! I bent the spring to hold it firmer, and it still leaked. Then I got a piece of rubberized gasket material and cut it, and put it between the gasket and the lid, making it even tighter, but it still leaked. So I cut another gasket piece, and now have 2 of them under the main gasket, and it still leaks, but only slightly.
What is going on here? Is it just a defective design or what?
