Re: High end W9 head build up start to finish.
[Re: DavidDean]
#1302534
09/15/12 06:42 PM
09/15/12 06:42 PM
Posts: 1,784 PA
W5DART66
PA
Great Post, thank you! Do you have plans on a short block? These heads will need a home!
They are headed for australia going on 440ci aluminum Riter block.
![](http://i62.photobucket.com/albums/h83/w5dart66/18f2629524fa1dd6464c171ce8bd94b8.jpg)
Update on work putting guides in.
[Re: Otherlane]
#1302544
09/22/12 03:59 PM
09/22/12 03:59 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Good numbers sounds like Brett is bad a**.would those head work good on a 430 inch short block? Talking about a set that flows 399
my thought is that would be perfect..small ci motor would require tons of rpm (tuff on valve springs) 430 or 440 means less rev's and TONS of torque~! ![](/ubbthreads/images/graemlins/apimp.gif)
[Re: Otherlane]
#1302548
09/26/12 08:46 AM
09/26/12 08:46 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
900 hp in a 2900 pound car should go how fast? i know other thing factor in that but a guess is all im asking
Depends...
Proflite, converter, Dewco, tire size, forward scoop, etc.etc.etc....
Re: High end W9 head build up start to finish. *DELETED*
[Re: mafo]
#1302551
10/11/12 08:20 PM
10/11/12 08:20 PM
Posts: 1,784 PA
W5DART66
PA
