Page 2 of 4 1 2 3 4
Re: High end W9 head build up start to finish. [Re: pittsburghracer] #1302533
09/13/12 11:22 AM
09/13/12 11:22 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Great Post, thank you! Do you have plans on a short block? These heads will need a home!
Re: High end W9 head build up start to finish. [Re: DavidDean] #1302534
09/15/12 06:42 PM
09/15/12 06:42 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
They are headed for australia going on 440ci aluminum Riter block.
Update on work putting guides in.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302535
09/15/12 07:57 PM
09/15/12 07:57 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
We gotta know more as that project proceeds
Thanks again for the post!
Re: High end W9 head build up start to finish. [Re: DavidDean] #1302536
09/15/12 09:43 PM
09/15/12 09:43 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Putting guide in.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302537
09/15/12 09:45 PM
09/15/12 09:45 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Ream hole for my head bolt sleeve set up.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302538
09/15/12 09:46 PM
09/15/12 09:46 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Pic of head bolt sleeve.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302539
09/15/12 09:49 PM
09/15/12 09:49 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Sleeve 2
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302540
09/15/12 09:53 PM
09/15/12 09:53 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Not this set of heads but cool pic of cnc w9 on 4.200 bore.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302541
09/21/12 07:23 AM
09/21/12 07:23 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Go to know these heads will support 440 c.I.what valve size?any idea on flow numbers you're looking for? Do you know anything about the short block the heads going on?
Re: High end W9 head build up start to finish. [Re: Otherlane] #1302542
09/21/12 11:11 AM
09/21/12 11:11 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
my bud has a set of those w9's from w5...flow is 399@ 800+ lift w some left on the table nice thread w5.
Re: High end W9 head build up start to finish. [Re: fishy340] #1302543
09/22/12 09:57 AM
09/22/12 09:57 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Good numbers sounds like Brett is bad a**.would those head work good on a 430 inch short block? Talking about a set that flows 399
Re: High end W9 head build up start to finish. [Re: Otherlane] #1302544
09/22/12 03:59 PM
09/22/12 03:59 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
my thought is that would be perfect..small ci motor would require tons of rpm (tuff on valve springs) 430 or 440 means less rev's and TONS of torque~!
Re: High end W9 head build up start to finish. [Re: fishy340] #1302545
09/22/12 09:36 PM
09/22/12 09:36 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I have 430 inches now and a new set of w9s just getting info on what these heads are capable of
Re: High end W9 head build up start to finish. [Re: Otherlane] #1302546
09/22/12 10:20 PM
09/22/12 10:20 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
bes racing engines or extreme here on long island,,,i bet could get 900hp from those w9's
Re: High end W9 head build up start to finish. [Re: fishy340] #1302547
09/26/12 08:41 AM
09/26/12 08:41 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
900 hp in a 2900 pound car should go how fast? i know other thing factor in that but a guess is all im asking
Re: High end W9 head build up start to finish. [Re: Otherlane] #1302548
09/26/12 08:46 AM
09/26/12 08:46 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Depends...
Proflite, converter, Dewco, tire size, forward scoop, etc.etc.etc....
Re: High end W9 head build up start to finish. [Re: jim sciortino] #1302549
09/26/12 09:45 AM
09/26/12 09:45 AM
Finland
mafo Offline
mafo  Offline
Finland
about 8.69...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: High end W9 head build up start to finish. [Re: mafo] #1302550
10/11/12 08:19 PM
10/11/12 08:19 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Small update all guides in and counter bores cut for exhaust seats/seats installed.
Next will be on to CNC heads.
Re: High end W9 head build up start to finish. *DELETED* [Re: mafo] #1302551
10/11/12 08:20 PM
10/11/12 08:20 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Post deleted by W5DART66
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302552
10/11/12 08:21 PM
10/11/12 08:21 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Ex seats
Page 2 of 4 1 2 3 4
