Re: timming gear spins free on crank snout. HELP
[Re: 68528hemi]
#1302465
09/11/12 11:50 PM
09/11/12 11:50 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Sounds like you need to measure the snout on that crank,I would think that some resistance should be there when the gear is installed on the crank with the keyway as a guide for location.Maybe Dan or one of the other machinist/builder will chime in.
