Dana 60 ? #1302319
09/11/12 09:10 PM
09/11/12 09:10 PM
Stratford,Ct
7sec.cuda Offline OP
Stratford,Ct
need to put a new dana 60 in my racecar question is are all dana 60s the same truck or car?other then length i will narrow it anyway i was just hoping to find a good housing to put all my stuff in thanks
Re: Dana 60 ? [Re: 7sec.cuda] #1302320
09/11/12 09:12 PM
09/11/12 09:12 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
IIRC the truck dana 60's did not have the mounting for a pinion snubber. I don't know if you are using a pinion snubber, I'm no racecar expert.
Re: Dana 60 ? [Re: BEINGmeISaCRIME] #1302321
09/11/12 10:09 PM
09/11/12 10:09 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
this is correct , truck dana 60's do not have a provision for a pinion snubber , as long as you don't need one then you can use a truck housing . Just make sure it's not a dana 61 , also note some truck housing MIGHT have a bigger axle tube diameter .
Re: Dana 60 ? [Re: 7sec.cuda] #1302322
09/12/12 01:07 AM
09/12/12 01:07 AM
Not all Dana 60 truck hosing and axle tubes are alike Some have 2.5 inch diameter axle tubes, some have 3.0 inch like the Mopar passenger cars had, some are 3 1/8 and some are 3 1/4 is what I have seen or heard of I am using a 3 1/8 truck housing out of a Ford 3/4 ton pick up. I have another Dana 60 out of a Dodge 3/4 ton long van but I haven't measured the axle housing diameter yet, it is real wide and has lot longer driver side axle tube than normal Hopefully it will work for my 1965 Dart tube chassis 4 link deal
Re: Dana 60 ? [Re: Cab_Burge] #1302323
09/12/12 09:44 AM
09/12/12 09:44 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
