Re: Hemi Superbird Air Cleaner Shield ?
[Re: lrtexpress]
#1301733
09/10/12 11:54 PM
09/10/12 11:54 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Yes, a Hemi Superbird is "supposed" to have a shield in front of it. It would have been normal for any car NOT equipped with fresh-air (N96) to have a shield, whether it be 6bbl or 8bbl... This particular air cleaner had a notch cut into it for some reason, but it shouldn't be there.. This particular picture the car has an incorrect breather on the pass. rear valve cover. Incorrect base, but proper breather on valve cover... Now, I'm sure there were those examples that got out without the shield...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: ScottSmith_Harms]
#1301737
09/11/12 01:57 AM
09/11/12 01:57 AM
Posts: 17,527 Las Vegas, NV
6bblgt
Las Vegas, NV
I believe HEMI Superbirds may have been delivered without the shield, but that would've been a mistake, due to availability or simply human error. Should a restoration reflect a human error or undocumented/mythical lack of a correct part at production? * Before the Superbirds existence there were NO non-N96 HEMI cars being built at the Lynch Rd. assembly plant. * The shield'd non-N96, or N95 equipped air cleaner would've been a RARE sight at Lynch Rd. pre-Superbird, but would've been in the parts system & readily available a few miles away in Hamtramck. * Anyone have a broadcast sheet or window sticker showing a N95 - "CA emissions" (& NO tip) - Lynch Rd. assembled HEMI car. HEMI Superbirds account for nearly 1/4th of HEMI b-body production in 1970 & all were built during November & December of '69. I find it likely, that the Lynch Rd. plant had sufficient production planning info with enough lead time to have "SHIELDED" air cleaners on hand for HEMI Superbird production. There aren't a bunch of HEMI Superbirds with the firewalls punched with "AIR GRABBER" holes are there? So, they had to have procedures in place to build the ~2000 'Birds. ![](/ubbthreads/images/graemlins/wrench.gif)
[Re: lrtexpress]
#1301738
09/11/12 02:12 AM
09/11/12 02:12 AM
6bblgt
Las Vegas, NV
Makes sense with the removals. What is your guess on percentage of N96 cars versus Non fresh air cars with that style air cleaner?
I would put a larger percentage of them removed "in-the-day" for dual "firestarter" or chrome air cleaners. ![](/ubbthreads/images/graemlins/apimp.gif)
(~135) All HEMI Superbirds non-N96 (~125) All HEMI Charger R/Ts (& 1-500 ) non-N96 (~280) Most HEMI Challenger R/Ts non-N96 (# is WAG) (~?30) & a few "CA emission" HEMI Runners, GTXs, Coronet R/Ts and Bees (# is WAG)
~570 Sheilded HEMI air cleaners for '70 production (~37%). ~725 "SHAKER" HEMI air cleaners for '70 production (~47%). ~260 "RAMCHARGER"/"AIR GRABBER" HEMI air cleaners for '70 production (~16%). (Also used on all (non-Charger) of '69 HEMI production)
[Re: gtx6970]
#1301743
09/11/12 02:23 PM
09/11/12 02:23 PM
6bblgt
Las Vegas, NV
RM23ROA - ( Yes it's a Bird )
this car had a warrenty shortblock installed in about 1973 or 74. Otherwise it's 100% as delivered.
..... but, wouldn't the 12 MONTH/12,000 MILE WARRANTY have run out by then? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: 6bblgt]
#1301744
09/11/12 02:38 PM
09/11/12 02:38 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Just what did the restricted warranty on 6bbl and Hemi cars cover or not cover ?
[Re: lrtexpress]
#1301745
09/11/12 09:56 PM
09/11/12 09:56 PM
Posts: 21,517 It's a dry heat
gtx6970
It's a dry heat
Thanks for sharing that shot, see little LimeLight hiding under that old black paint, would you have a shot from the other side, curious on angle of hose off breather and connection to air cleaner?
Is this car still hiding in the barn or been polished up?
It's still sitting exactly the way it shows in this picture. Current owner bought it I know at least over 20 years ago, and has never heard it run (came out of the Toledo Ohio area) FJ5 , Hemi, 4spd , blk int , console. The black underhood is actually that spray on rust proofing and not paint
[Re: gtx6970]
#1301746
09/11/12 09:59 PM
09/11/12 09:59 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Man would I love to own that car! That's my "perfect" Superbird right there!
[Re: 6bblgt]
#1301747
09/11/12 10:05 PM
09/11/12 10:05 PM
gtx6970
It's a dry heat
Dan, I can't answer that one. (Going off of memory so don't shoot me) but when we went to look at the car. Then owner told us the 1st owner scattered the shortblock and Mopar replaced it, Not 100% sure WHO paid for said shortblock. And I'm not 100% sure the time frame it was replaced. Thats been a while back.
It's NOT the original shortblock.but it does have the original 1970 top half
#1301748
09/11/12 10:08 PM
09/11/12 10:08 PM
gtx6970
It's a dry heat
you and several others. I've been trying to get the current owner to at least put a running drivetrain in it ( he has several on hand) and drive it. But it just sits,,,and sits,,,,,and sits. At least he's had it stored indoors all this time
[Re: 62maxwgn]
#1301750
09/12/12 07:42 AM
09/12/12 07:42 AM
hemi68charger
Houston, Tx
Bill,if it belongs to who I think it does,it will continue to sit and sit and sit !!
What a shame.. I was like that... 3 out of 4 cars just sat, sat and sat till that one day I was going to hit the lotto to fix them all. Now I've seen the light and I have 2 cars and 1 that runs, runs, runs.. ![](/ubbthreads/images/graemlins/biggrin.gif)
And now, money to spare for the other one to get it to run, run, run..
