vacuum canister inside air cleaner #1301717
09/10/12 08:52 PM
09/10/12 08:52 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
OK, how does this thing work? One vacuum line goes into it from the carb...the other line goes to the canister on the air cleaner snorkel for the heat tube door.
Does it block vacuum when it gets hot so the air door in the snorkel closes? When these go bad I assume they let vacuum pass all the time?
Is there an inlet and an outlet side or can I hook up the hoses to either nipple?
Re: vacuum canister inside air cleaner [Re: burdar] #1301718
09/10/12 08:57 PM
09/10/12 08:57 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
When cold it lets vacuum through closing off the snorkel pulling air from the heat stove on the exhaust manifold. I am pretty sure you can hook up either way.
Larry
Re: vacuum canister inside air cleaner [Re: Moparlar] #1301719
09/10/12 09:05 PM
09/10/12 09:05 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
So right now at room temp it is letting vacuum pass through. If it is bad, it will try holding the door open all the time correct?
Re: vacuum canister inside air cleaner [Re: burdar] #1301720
09/10/12 10:14 PM
09/10/12 10:14 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
I am not sure at what temp it closes, but I would think at room temp it would be closed. I will look tomorrow I might have an NOS one and I will test it.
Larry
