Re: Space Saver Spares
[Re: RestoreCuda]
#130092
09/30/08 12:28 PM
09/30/08 12:28 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
This is the correct wheel and tire out of my T/A. 04/06/70, Hamtramck plant.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: RestoreCuda]
#130096
09/30/08 12:59 PM
09/30/08 12:59 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
The last picture posted shows a K2 with a 9 under it. That is the year date code for the rim. 9 is for 1969. All the REAL space saver rims have that stamping with either a 9(1969),0(1970), or 1(1971). The K is for Kelsey Hayes, the OEM of the rims. All rims are 14". Kelsey Hayes also made 15" rims that also have the sixth hole, they were for C Body cars, they are not for spacer savers. Sometime in Jan or Feb. of 1971 the rims were changed to five hole, they were still made by Kelsey Hayes. There are date codes stamped on either side of the valve stem hole on these rims as well. The number(s) to the left of the hole are for the month code. The number(s) to the right of the hole are for the day code. If you are looking for a space saver to mate up to your car you need to find a rim dated sometime previous to the SPD of your car. Troy, can you post some pics. showing the date code of your rim? I can post some tonight if you want. Early space saver tires were 7.75x14 B.F. Goodrich, they were changed to F78x14 somtime in September of 1969. They were used on cars with both 14" or 15" equipped cars in 1970. At the end of the 1970 production year and into 1971 they also used 7.35x14 tires along with E78x14 tires. These were for cars equipped with 14" rims and tires. The rims were still the same Kelsey Hayes ones in all cases. NONE of these rims ever had a seven digit part number stamped above the valve stem hole. Did I miss anything?
[Re: m46rat]
#130104
09/30/08 02:56 PM
09/30/08 02:56 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
I was told that when Chrysler changed to the larger red air bottle they found out that it was possible to over inflate the space saver tires. So they came out with a valve stem that was equipped with a built in pressure relief valve and added the second warning label. I don't know which car it came out of, I can't find my notes relating to it.
