Re: 68 Charger valance end caps and ????????????
[Re: Thread Ender1]
#1300775
09/09/12 09:29 PM
09/09/12 09:29 PM
Posts: 18,160 Mass
DAYCLONA
Mass
How can the seam that attaches the cap to the 1/4 panel be welded or tacked. I will supply a few pics , any ideas for those who have done it.
I mocked my rear valance and end caps up on the car where I wanted them, just a few tacks to hold all 3 pcs together, then removed them from the car as 1 piece and welded the end caps from the backside to the valance, then drilled a few holes on the rear qtr tabs that the end caps mate to, then plug welded the end caps to the flange from under the trunk extensions, and welded the rear valance to the car as 1 assembly, this way you have no weld "dressing" to do on the end caps, other than a small application of seam sealer embedded in the seams of the end caps to prevent rust, but not to much that you lose the end caps seam definition
Mike
[Re: Thread Ender1]
#1300776
09/10/12 11:14 AM
09/10/12 11:14 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
The seam between the end cap and the rear valance didn't have seam sealer, it was left open. Now, the seam between the end cap and the quarter did have seam sealer. That seam is exposed to the inside-trunk area. The cavity behind the end caps wasn't filled with anything.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1300777
09/10/12 01:12 PM
09/10/12 01:12 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Agreed, but it's also one of the reasons all 2nd gen Charger rear valances blow out from rust, it's best to seam seal the corners in IMHO, and seal them up from hidden moisture/rust forming...these cars where built haphazzard from the factory, unless the OP is going for the Gold, i see no reason to not improve upon the factory's errors or misgivings in a restoration
mike
[Re: DAYCLONA]
#1300778
09/10/12 01:21 PM
09/10/12 01:21 PM
hemi68charger
Houston, Tx
mike
I agree Mike, but what do you do for the complete bottom side of the valance being open to the elements as well? I would think the more ciculation of air you have, the better the chances of moisture not getting trapped.....
