What's the Best Way To Remove Sprayed on Adhesive? #1300495
09/09/12 04:37 PM
09/09/12 04:37 PM
dart1962_440 Offline OP
My brothers Dodge had the carpet installed with spray adhesive. Any thoughts on what to use to get the adhesive off the floor pans? Mineral spirits, brake cleaner and grease & wax remover didn't work.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300496
09/09/12 04:57 PM
09/09/12 04:57 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Goo Gone or alcohol? If the adheasive is still flexible. Just guessing here. I have used both on a smaller scale.I think I've even seen wd40 work.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300497
09/09/12 06:55 PM
09/09/12 06:55 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
3M does make an adhesive remover but it's expensive and would'nt be cost/work effective for that broad of an area... Just a thought...Did you try lacquer thinner ???
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: screamindriver] #1300498
09/09/12 07:12 PM
09/09/12 07:12 PM
I haven't tried lacquer thinner yet, but will add it to my list of removers to try. Goo-gone didn't work.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300499
09/09/12 07:41 PM
09/09/12 07:41 PM
DO NOT use laquer thinner Painters alcohol, can't remember the correct name for it or Goo Be Gone, maybe. The proper name of that alcholol is Denatured alcholol Use it liberally and scrub, scrub and scrub some more until it is gone
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: Cab_Burge] #1300500
09/09/12 08:04 PM
09/09/12 08:04 PM
Acetone sort of works.
Thanks for the tip on the lacquer thinner, I'll try some denatured alcohol in a small area to see if it works.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300501
09/09/12 08:38 PM
09/09/12 08:38 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just bought some 3m adhesive remover. That stuff works awsome. It took off the excess vinyl top adhesive and didn't hurt the paint.
It's expensive but it will get the job done quickly.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: burdar] #1300502
09/09/12 08:52 PM
09/09/12 08:52 PM
What part number did you get? There seems to be a couple diff ones.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300503
09/09/12 09:09 PM
09/09/12 09:09 PM
Do not use Acetone on paint that you want to keep looking good, it is harder on paint than laquer thinner is
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: Cab_Burge] #1300504
09/09/12 09:35 PM
09/09/12 09:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
3M General Purpose Adesive Cleaner #08984
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: burdar] #1300505
09/09/12 09:54 PM
09/09/12 09:54 PM
Thanks!!
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300506
09/12/12 09:46 PM
09/12/12 09:46 PM
Thanks!!
That p/n is no longer available. I ended up getting it's replacement and on initial testing, works well. We'll see how it works when I get a change to do the whole floor.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300507
09/12/12 09:58 PM
09/12/12 09:58 PM
IN
ahy Offline
ahy  Offline
IN
Good choice if you want to keep the paint. On mine, I needed to re-paint so I used a heavy cup wire wheel in an angle grinder. Adhesive, sticking bits of carpet, paint and crud all came off.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: ahy] #1300508
09/12/12 10:08 PM
09/12/12 10:08 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Most adhesives use hexane as the base solvent. It can be difficult to find so an alternative is lighter fluid (not the same carbon chain as hexane but will work similiar)
NOTE: Before you apply the solvent to the carpet check a small inconspicuous spot that won't be seen to ensure that there is no color fade of the carpet
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: C_B5] #1300509
09/12/12 11:47 PM
09/12/12 11:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Funny as I just bought that number last week. It must have been on the shelf for a long time.
Re: What's the Best Way To Remove Sprayed on Adhesive? [Re: dart1962_440] #1300510
09/13/12 08:52 PM
09/13/12 08:52 PM
It works well on the thin stuff. When you hit a spot of thick adhesive it works very slowly. I have a lot of thick spots...
Thanks everyone on the responses & advice.
