E-body brakes on a-body?
#1300336
09/09/12 11:46 AM
09/09/12 11:46 AM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
Can I use the manual drum front brake setup from a 1972 Cuda to replace the original manual drums on my 1970 duster, in order to take advantage of the large bolt pattern? Would I have to use the spindles too and would this adversely affect the suspension geometry? I've purchased a disc brake setup for my Cuda, so I thought this may be a cost effective way to use some of my 4 1/2" wheels on the duster. Thanks!
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
Re: E-body brakes on a-body?
[Re: Fishmarket]
#1300337
09/09/12 01:24 PM
09/09/12 01:24 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You'll need a set of 73-76 upper control arms to get the bigger ball joint that fits the spindle...
[Re: 1_WILD_RT]
#1300338
09/09/12 04:08 PM
09/09/12 04:08 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
If your going to the trouble of changing the upper A arm and spindle to the larger bolt pattern you might as well convert to discs..
I am truckless..
